moonrise missing
Ettershaus
moonrise missing
Post by Ettershaus »
i miss the Values of the Moonrise-Time.
I'll get only:
actual_sunset_nauticaltwilight_local 17:52
actual_moonset_standard_local 13:45
actual_moonset_standard_utc 12:45
actual_th0_temp_c 7.4
At my other Weatherstation, I'll get 0:36 as Moonrise-Time (calculated with a differend programm)
Meteohub 4.5i (also with 4.5h, prior the update)
WS Grave
Re:moonrise missing
Post by WS Grave »
Hi Ettershaus, see this posting.
Since the new update I'm also missing the moonrise time.
But you say this was already so with the prior version!?
bensca
Re:moonrise missing
Post by bensca »
I have version 4.5g and miss [actual_moonrise_standard_local] too. But just the last two days.
sevenless
Re:moonrise missing
Post by sevenless »
Moon rise is most likely missing the past few days because there wasn't a moon rise during that 24 hour cycle!
Remember that the moon rise/set cycle is not synchronized with the 24 hour solar cycle, but is somewhat longer (especially in northern hemisphere autumn/winter), causing some days to not have a moon rise or moon set.
I recommend you check the astronomy data at a reliable source (wunderground.com for example) and verify if you should see a moon rise in your data today -- there is none for me, so the lack of an entry in Meteohub is not surprising.
Ettershaus
Re:moonrise missing
Yup, that's logical ;-)
I've change my script to show "not today", when there isn't a value for the moonrise or -set.
