Solar Radiation html Tag
Casappa
Post by Casappa »
Hi all,
does anyone know why the html tag
[actual_sol0_radiation]
does not works using Davis VP2 and Meteohub 4.5i
Thank You.
Alberto.
d_l
Re:Solar Radiation html Tag
Post by d_l »
I don't think there is a tag of that name. If you want the solar output in watts/sq m it is [actual_sol0_radiation_wqm].
Casappa
Post by Casappa »
Thank You for your promt reply.
Now does work as well.
May be this tag must be included in the manual at the tag list section.
Alberto.
d_l
Post by d_l »
Have your Meteohub output a copy of the all-sensors data to an all-sensors.txt file. Then look through that file to find all names of the html tags available with a VP2.
