My new page is http://www.napajedlaci.cz
I count only a few days and so many do not offer information other than graphs. Still trying to met a good web design. What do you think my work - what would you have changed?
Weather in Czech republic with good webdesign
Re:Weather in Czech republic with good webdesign
I like it!
That is a very good example what gnuplot can do apart from the Meteohub standard settings. I think quite a few users here would like to learn about your special "format-cmd" settings.
hi,
yes quite good web-design.
Maybe you´re a professional?
You could use the "set xzeroaxis 1" on your temp graphs, because with the minus degrees it gives your visitors a quicker view about the temp scale.
the 1 above is the color of the zeroline. you can increase that number for other colors more siutable for your graphs.
Wolfgang
Wolfgang
Thanks so much for "set xzeroaxis 1", but how do I set up the line for this color? How to set the chart to show where the data more current http://www.napajedlaci.cz/aktualni-pocasi/
Chart upload after 10 minutes, but the chart is the last time from 11:40 h and not like the line tight end.
