Visit my website and click in the menu on "Verleden weer". See the table at the bottom.
/edit:
The code messed up the screen.
Now you can download the template.
Using _kmh in place of _kn doesn't seem to work with these variables (maybe because they were designed with WDL support in mind) but you can do use the template maths functions to apply a multiplier, e.g:WS Grave wrote:The wind is shown in knots. Does anyone know how to change that to km/h ?
Sorry, I don't have a neat trick for that.WS Grave wrote:Do you have a way to translate the wind direction degrees to N-W-S-E ?
well, always, but I would be happy if Boris could implement additional IF..THEN operators with the already existing logic of meteohub;)skyewright wrote:Sorry, I don't have a neat trick for that.WS Grave wrote:Do you have a way to translate the wind direction degrees to N-W-S-E ?
Probably a case for a bit of javascript (or php if you use php)?
