How to have the [actual_localdate2] in my web page ?
citi
Post by citi »
I need to have the [actual_localdate2] in my web page Index.html, how to do it ?
YJB
Re:How to have the [actual_localdate2] in my web page ?
Post by YJB »
<Sorry about he mess, not sure how to get this right in fireboard>
There are many ways to do this, but this is one to get you going:
[ This assumes that you did configure meteohubs' push services already]
Step 1:
create the following file on your meteohub
meteoplug:/data/graphs# cat /data/graphs/test1.html
"[actual_localdate2]"
This is not really a html file, but meteohub will need to know that this is a special file. Alternatively you could create the entire index.html on meteohub, but you probably want to put more in it.
Step 2:
a) In your meteohub GUI go to graph uploads
b) Select the file you just created
c) Select an upload schedule
d) Select the name of the file once it lands on your web server (this could be the same name)
Step 3:
On your web server include the uploaded file in your HTML, one way could be a shtml that contains:
<!--#include virtual=./<upload directory>/test1.html -->
By the way, in this case, if you just want to display the local date, you don't need meteohub at all, just include the following:
[b]Local time is <!--#echo var="DATE_LOCAL" -->.[/b]
You can include both of them on the same page, it will show you when the page was generated and the time meteohub uploaded the file to your webserver.
HTH
This is the complete webpage on the server in this case:
[v120] /data/www/default # cat test1.shtml
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<title>Untitled Document</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
</head>
<body>
Welcome....
<br>
<strong>
</strong>
<br>
<!--#include virtual=./weather_vars/test1.html -->
</body>
</html>
