Big problems after 2.2a/b update **solved**
peteroi
Post by peteroi »
Hi Boris,
after update from 2.2 to 2.2a are 3 problems:
1.
folder myweb replicates itself in myweb infinitely with all contents and subfolders - I had to stop upload to weather networks. But now I cannot delete folder myweb (with pc access to public area under windows...)
2.
HTML-templates do not show values but the names of the variables instead
3.
Dashboard is not working correctly, see here:
Going back to version 2.2 works fine - only folder myweb is not deleteable any more because of tpp much subdirs with the same name...
BR Peter
Pi/TE923
Chill
Re:Big problems after 2.2a update (2.2.b the same...)
Post by Chill »
BR Peter
Not so sure.... I'm in v2.1d and I'm experiencing same problem... as I posted a few hours ago.
So is previous to 2.1d. But the problem just happens from time to time, and if you don't edit dashboard edit page, it returns to normality after a while...
Chill
1) endless repeating sub folders is originated by a bad symlink. will be fixed in 2.2c
2) Missing actual data in dashboard goes ahead with not having replaced the corresponding sensor names in html templates.
3) When installing a new update the history data gets recomputed from scratch.. so please give meteohub some time (30 mins i.e) to get finished with this.
peteroi
Post by peteroi »
Hi Boris,
with upgrades higher than 2.2 (without a,b,c,d) the already mentioned problems with dashboard and HTML-templates seem to result from this (see following part of meteohub.log):
\"logger (28.03.2008 14:06:52): USB chip set: Vendor=1130 ProdID=6801 Rev= 3.01
logger (28.03.2008 14:06:53): Mebus hardware version 3.
logger (28.03.2008 14:09:17): started (mode 4).
logger (28.03.2008 14:09:17): USB chip set: Vendor=1130 ProdID=6801 Rev= 3.01
logger (28.03.2008 14:09:19): Mebus hardware version 3.
logger (28.03.2008 14:10:01): started (mode 4).
logger (28.03.2008 14:10:01): USB chip set: Vendor=1130 ProdID=6801 Rev= 3.01
logger (28.03.2008 14:10:02): Mebus hardware version 3.
logger (28.03.2008 14:11:22): started (mode 4).
logger (28.03.2008 14:11:22): USB chip set: Vendor=1130 ProdID=6801 Rev= 3.01
logger (28.03.2008 14:11:23): Mebus hardware version 3.
logger (28.03.2008 14:11:52): started (mode 4).
logger (28.03.2008 14:11:52): USB chip set: Vendor=1130 ProdID=6801 Rev= 3.01
logger (28.03.2008 14:11:54): Mebus hardware version 3.
logger (28.03.2008 14:12:22): started (mode 4).
logger (28.03.2008 14:12:22): USB chip set: Vendor=1130 ProdID=6801 Rev= 3.01
logger (28.03.2008 14:12:24): Mebus hardware version 3. \"
It seems that the NSLU2 starts every few minutes by new, then clearly there is no time to calculate dashboard and HTML, all-sensors.xml stays empty...
I already had setup completely new installation (on 2GB stick and on 4GB stick) with NSLU2 firmware 2.2, new meteohub software 2.2, then all is totally ok.
After upgrading to 2.2d its the same again - new starts every few minutes...
BR Peter
Pi/TE923
peteroi
Post by peteroi »
sorry- double sent...
Pi/TE923
this seems to happen on some TE-923. The diagnosis, that the data logger starting again and again prevents meteohub to provide data is correct.
Root cause seems to be that the logger throws a \"segmentation violation\" that is caught by the wrapping process that restarts the logger. So data is logged but no normal operation.
The reason for the segmentation violation is yet not found, but I have version here that looks like not producing this. I would like to give it a test drive at your system. please send me some data how to access your meteohub to test this (i need ssh access on port 22).
I assume this is fixed with 2.2e
peteroi
Post by peteroi »
Hi Boris,
after installation of 2.2e it looks very good - no new starts any more !:) Data calculation is OK now !
Thanks for this very good work !:)
BR Peter
Pi/TE923
