Linksys NSLU2 Problem with wunderground
fiarumbc
Post by fiarumbc »
I have been trying to connect my Linksys NSLU2 weatherhub with a Vantage PRO2 to wunderground page, I already have a Vantage PRO2 with a Davis 6555 IP working (IBAJACAL21),and have this second one with wunder user IBCLARUM2, but is not working, it is not Active, I write the ID and password on the Weather Networks page of my weatherhub, I try connecting it with DHCP and with static IP on a home network and in a bussines network with all the permits to internet, but it doesnt work. In the System Info page the WAN IP: is "no internet access", I dont know what to do, I hope you can help me.:huh:
YJB
Re:Linksys NSLU2 Problem with wunderground
Post by YJB »
"no internet access" normally implies that your NSLU2 has no suitable connection to the internet.
Some things to explore:
On the system info page do you have entries for:
Gateway and DNS?
Also, might be that your internet router is blocking access from the NSLU2 to the internet?
Is your static ip:
Unique in your network
In the same subnet as your router?
Is the netmask the same as the one defined on your router?
HTH
fiarumbc
Post by fiarumbc »
I'm working side by side with the network administrator, we double check the network settings and all looks to be Ok. We already have a Vantage Pro2 working on wunder (IBAJACAL21), but is working with the Davis 6555 IP, in the network both have the same permits, obious with differents IP, but this one with the meteohub is not working, we try it also in a home network with dinamic IP and gateway config and the same results, the problem is that we brought 2 Vantage Pro2 with meteohub, I still need help to conect this 2 weather stations to wunder.
fiarumbc
Post by fiarumbc »
Thanks I do it but it didn't work, I try on diferent networks, but the same result :dry:
Please post me a screen dump of "System Info" and "Network" page.
fiarumbc
Post by fiarumbc »
This are the settings:
You need to specify a DNS.
You can try with your gateway's IP or with Google DNS 8.8.8.8 or with the one your provider has given to you.
cbhiii
Post by cbhiii »
I use Google on my system. It works great and I don't have to worry about DNS anymore.
