Install 1wire on meteohub
I know some people have running a 1wire system on meteohub.
Can you say what i have to do to read the sensors?
I've installed owfs by
* Downloading
* Extracting
* ./configure
* ./make
* ./make install
but now I'm stuck.
I want to read the sensors with perl.
edit: i'm using the usb-adaptor
* Downloading
* Extracting
* ./configure
* ./make
* ./make install
but now I'm stuck.
skyewright
Re:Install 1wire on meteohub
If I've understood correctly, then at this stagePeriklast wrote: but now I'm stuck.
For a DS9490 USB adaptor:
perl -MOW -e "OW::init('u'); printf OW::get('');"Code: Select all
DEFAULT: Opened USB DS9490 adapter at 002/002.
You'll also need to mount the 1-wire system for which you need fuse. e.g.I want to read the sensors with perl.
mkdir /home/1wire
mkdir /home/1wire/mnt
modprobe fuse
/opt/owfs/bin/owfs u /home/1wire/mnt
ls /home/1wire/mnt
e.g.
10.A78B94010800 1F.72D303000000 26.D55BB6000000 settings system
1D.04010E000000 1F.F5D303000000 81.FD4927000000 simultaneous uncached
1D.5CEB09000000 26.3F59B6000000 alarm statistics
1F.63D603000000 26.C3A5BC000000 bus.0 structure
fuse
line to /etc/modules
Then you get your perl to read from the relevant pseudo-files on /home/1wire/mnt.
Does that make sense?
It seems you have to install fuse.
I installed fuse and after that, I tried to re-install owfs (because /opt/owfs/bin/owfs doesn't excist) (it was disabled by configure.
So I run follow command:
but at the end, it gives me an error:
I editted the /etc/ld.so.conf to
followed by ldconfig but the error remains.
edit: libfuse.a exist in /usr/local/lib
./configure --enable-owfs --enable-owperl
checking for fuse_main in -lfuse... no
configure: WARNING:
Can't find libfuse.a - add the search path with --with-fuselib
configure: WARNING: Running ldconfig or adding "/usr/local/lib" to /etc/ld.so.conf might also solve the problem, otherwise re-install fuse.
configure: error: Can't enable OWFS
include /etc/ld.so.conf.d/*.conf
/usr/local/lib
skyewright
Checking my notes I didPeriklast wrote:It seems you have to install fuse.
apt-get install fuse-utils libfuse-dev
Did you get libfuse aswell as fuse?
Thanks, now it works! Now i'm figuring out how to use the files in /home/1wire/mnt
I managed to read the solar and uv sensor and add it to meteohub.
BUT, everything works ok if I don't give the sensors any ID and name. From the moment I give the sensors an ID, the plugin don't work anymore.
And I gave sol0 id sol0 and uv0 id uv0
Next, I'm gonna connect my lightning detector (counter) to 1wire and meteohub. What will be the sensortype? Rain/Data/...?
#!/usr/bin/perl -w
use strict;
use IO::Handle;
my $solarid = "26.7DD1F1000000";
my $uvid= "EE.CB34CB010800";
my $oldsolarvalue = 0;
my $olduvvalue = 0;
sub trim($)
my $string = shift;
$string =~ s/^\\s+//;
$string =~ s/\\s+$//;
return $string;
sub GetSolar(){
my $cursol = $oldsolarvalue;
eval{
my $file = "/home/1wire/mnt/$solarid/vis";
open (SOL,$file) || die();
my $read=<SOL>;
close(SOL);
my $solar = trim($read);
$cursol = int($solar*4000);
$oldsolarvalue = $cursol;
if ($@){
print "sol0 $cursol\\n";
sub GetUV(){
my $curuv = $olduvvalue;
eval{
my $file = "/home/1wire/mnt/$uvid/UVI/UVI";
open (UVI,$file) || die();
my $read=<UVI>;
close(UVI);
my $uvi = trim($read);
$uvi = $uvi*10;
$curuv = $uvi;
$olduvvalue = $uvi;
if ($@){
print "uv0 $curuv\\n";
STDOUT->autoflush( 1 );
while ( 1 )
GetSolar();
GetUV();
sleep( 30 );
skyewright
I've no immediate ideas on that. I'm assuming that you have taken a look in the meteohub log to see if anything is being reported there?Periklast wrote:From the moment I give the sensors an ID, the plugin don't work anymore.
I use data.Next, I'm gonna connect my lightning detector (counter) to 1wire and meteohub. What will be the sensortype? Rain/Data/...?
yes, it's strange. I don't see anything in the log.
If I give an id to UV (ex uv0/uv1) it works but add an id to the solar, the plugin stops working.
It stops after reading the first plugin-sensor.
If I first output the uv and then the solar, only uv is seen (sometimes solar) but there is no refresh of both sensors.
If I first output the solar, only the solar is seen (sometimes) and no uv is seen. There is also no refresh.
skyewright
Maybe you could add some temporary debugging aids to your code, e.g. write notes to a file at various points in the code then see if those notes help pin down what's happening?Periklast wrote:yes, it's strange. I don't see anything in the log.
I did some advanced debugging. I don't see any error in the output.
What I see is that the script is running all the time and output everything correctly. Except, meteohub doesn't trace all the output, except the first line.
skyewright
Does this minimal dummy plug-in work for you? It does on my ALIX-1DPeriklast wrote:What I see is that the script is running all the time and output everything correctly. Except, meteohub doesn't trace all the output, except the first line.
#!/usr/bin/perl -w
use strict;
use IO::Handle;
my $value = 1;
while ( 1 )
print "sol0 $value\\n";
$value++;
sleep( 5 );
I've tried it now and it works only if you not give it an id (ex sol0-sol1). Seems only to happen sol.
edit: how to implement the lightning counter? I see counters.A / counter.B and counters.ALL
skyewright
Haven't we been here before?Periklast wrote:I've tried it now and it works only if you not give it an id (ex sol0-sol1). Seems only to happen sol.
i.e. http://www.meteohub.de/joomla/index.php ... rt=12#7327
Are you using vmware or your ALIX?
I'm using Alix now and I have the same problem as vmware.
Don't know why, maybe advanced logging by meteohub itself?
skyewright
Perhaps.Periklast wrote:Don't know why, maybe advanced logging by meteohub itself?
What happens if you modify your perl to report the solar values as a "data" sensor instead of a "sol" one?
If itworks as data then you are at least recording something and the problem is further isolated.
