wind0 -07 intepretation
HWTest
Post by HWTest »
I think I've found another problem:
wind0 90 15 13 06
Windchill is intepreted right as 0,6
but
wind0 45 26 21 -08
Windchill is intepreted (in graphs) as -8 and I think it should be -0,8
but
wind0 180 0 0 -011
Windchill is intepreted correctly as -1,1
Running 4.6G on SheevaPlug.
Re:wind0 -07 intepretation
I can confirm this bug. Will be fixed with coming 4.6h.
HWTest
Post by HWTest »
I've found this bug in th (thermo/hygro) dew point interpretation also.
Yep, same reason, will also be fixed.
HWTest
Post by HWTest »
I've upgraded to 4.6h, recomputed the data but
wind0 45 26 21 -08
is still interpreted (in graphs) as -8
Running 4.6h on SheevaPlug
that needs a fresh import. Importfunction has changed.
HWTest
Post by HWTest »
OK, I'll do that.
I have one additional question: Where is the Windchill temp taken from during the import?
It seems that it is computed from the th0 temperature and the wind?
HWTest
Post by HWTest »
Never mind, I've figured it out.
It takes it from t0 or th0, so I had to play a little bit with the column numbers in the import file, that the raw file matches my sensors.
