790+ mm. instead of the actual 12.81 mm.
WS Grave
Post by WS Grave »
Meteohub crashed today and after restart (and installing the new n-version) I have 790+ mm's.
How do I correct that!?
Please help!
Re: 790+ mm. instead of the actual 12.81 mm.
Please make a graph to find the time stamp where the problem comes from, then look at raw data with inspect data page. Maybe there is a hickup in there. When you see errors about bad data in "meteohub log" try cleaning up the corresponding raw data.
WS Grave
Post by WS Grave »
Hi Boris, I've tried several times and the last correction succeeded, but after that again the same troubles as this afternoon (no data, but correct rainfall).
I've just rebooted the Meteohub and am waiting for the result. It takes an hour (most times), so I've to wait for it.
Will let you know.
/edit:
Yes, it works, although I was 7 minutes to late for the end-of-day reset.
It's now 0.07 am and the yesterday data are still shown.
Do I have to reset the day or something!?
is it a NSLU2? Any interesing errors in "dmesg log" or "meteohub log"?
WS Grave
Post by WS Grave »
Hi Boris, no it's a Alix-1D and good news.
The day is reset by its self and all is working allright now.
Pfeewww :)
I still don't know what was causing this, but will keep an eye on things.
