How backuping Defined Graphs section ?
lcoulon
Post by lcoulon »
I'm with my station : it no longer able to read my sensors, i don't know why, i think my installation is corrupt.
I would like to perform a new installation in order to have a system cleared of any problems.
Before that, i would like to save all my Defined graphs available in Manage graph section, it is possible to backup them ?
If i go with a new installation , all my defined graphs will be lost, i spent much time to create them, is there a way to save them and put them back in my new installation ?
Many thanks for your help,
YJB
Re: How backuping Defined Graphs section ?
Post by YJB »
Your graphs can be accessed using the following path:
\\<meteohubname or ip>\public\graphs
The graphs all have a .mg extension
Personally I would probably backup the weather directory as well since it contains all you measurements.
lcoulon
Post by lcoulon »
Thanks, is there also possiblity to save "Graphs upload" section ?
I've done a backup of my previous settings , i got meteohub.conf file, but NSLU2 won't restore it :cry:
YJB
Post by YJB »
If you use the "backup settings" on the maintenance tab, you should use "restore settings" when restoring it.
Just overwriting meteohub.conf is probably not going to get your grahp uploads schedule back, since this is actually a number of lines in the crontab.
use "backup application data". This covers weather data, cron tab, graphs and all other settings.
lcoulon
Post by lcoulon »
When backup done, Meteohub says it is located here : /public/meteohub.backup
then, how to save that file on my desktop ?
i do not know how to access that folder on NSLU2.
YJB
Post by YJB »
It is located on the following share:
lcoulon
Post by lcoulon »
Well, i tried from Windows XP -> My Computer -> Map Network drive
and assigned a drive letter do \\metehub-ip\public
then i asks for a login & password, i used the one i usually use for getting web access but it won't work ...
Thanks for your help,
YJB
Post by YJB »
I believe the default is meteohub meteohub
lcoulon
Post by lcoulon »
meteohub / meteohub are accepted, i can now browse the public folder.
