Option to choose from which temp sensor WCH is calculated
Requests for future functionality
HWTest
Post by HWTest »
I would like an option to choose from which temp sensor Wind Chill is calculated.
Now it is hard coded to use the "primary outdoor sensor" - seems to be the first temp sensor in RAW data after the thb sensor.
Sensor definition has no effect on this, ie if I define any other sensor as th0, it still uses the "primary outdoor sensor" for the the Wind Chill calculation.
wfpost
Re: Option to choose from which temp sensor WCH is calculate
Post by wfpost »
couldn´t that be achieved with defining a Virtual Sensor?
Only problem might be that the windchill formula is only valid for wind speeds larger than 5 km/h:
"Windchill Temperature is only defined for temperatures at or below 10 °C (50 °F) and wind speeds above 4.8 kilometres per hour (3.0 mph)."
http://en.wikipedia.org/wiki/Wind_chill
HWTest
Post by HWTest »
wfpost wrote:couldn´t that be achieved with defining a Virtual Sensor?
Do you have an idea how?
