Hey everyone, Sense my former usb sticks died on me ( at least I think that is the problem ) I have been trying to get my NSLU2 back up and running . But buying a new Sandisk 4 gig stick and loaded the 4.6 dd using killbits I got the same results as before . So, then thinking it may be something to do with the hardware NSLU2 , I went ahead and reflashed it according to instructions outlined by Boiris . But here I am with same results .... no sensors assigned . Then after looking more closely at the meteohub log I think i found the problem , " bad file descriptor ' Does anyone know exactly what this means ? I hope my NSLU2 isn't fried .
METEOHUB LOG
logger (26.12.2010 22:56:20): parent process received termination signal (15).
logger (26.12.2010 22:56:21): child process received termination signal (15).
logger (26.12.2010 22:56:22): data logger started.
logger (26.12.2010 22:56:25): connect station 0 (TE-923 via USB HID).
logger (26.12.2010 22:56:25): connect station 1 (TE-923 via ).
logger (26.12.2010 22:56:59): parent process received termination signal (15).
logger (26.12.2010 22:56:59): child process received termination signal (15).
logger (26.12.2010 22:57:00): unexpected 0 bytes delivered from weather station 0 (TE-923)
logger (26.12.2010 22:57:00): disconnect station 0 (TE-923).
logger (26.12.2010 22:57:00): reading weather station 1 (TE-923) failed: Bad file descriptor
logger (26.12.2010 22:57:00): disconnect station 1 (TE-923).
logger (26.12.2010 22:57:00): data logger stopped.
logger (26.12.2010 22:58:22): data logger started.
logger (26.12.2010 22:58:25): connect station 0 (TE-923 via USB HID).
logger (26.12.2010 22:58:25): connect station 1 (TE-923 via ).
Bad file descriptor ?
Re: Bad file descriptor ?
please update to most recent 4.6u and try again.
Hello Boris, I did the 4.6 u upgrade but still have the "DEMO has expired " after doing a reboot . I tried several times reinstalling and even did a reset but am getting no where . So I guess I am doing something wrong .
MeteoHub Maintenance
15:07 27.12.2010
Warning: No weather station selected
Demo Version has timed out. You need an activation code for further operation (MAC: 00:18:39:AB:18:79).
Authorization
New Password
New Password
Activation Code
Manage SettingsRestore Settings
Backup Settings
Reset Settings
Application Data
System ControlAggregated Weather Data
Data Logging Process
Meteohub System
Scheduled Reboot never daily weekly monthly
Language File
System MaintenanceClone System Makes a copy of the USB-Stick that drives Meteohub to a fresh USB-Stick in slot "Disk 1". System shuts down when finished.
Software Update (Auto)
Software Update (Web)
Software Update (File)
15:07 27.12.2010
Authorization
New Password
New Password
Activation Code
Backup Settings
Reset Settings
Application Data
Meteohub System
Language File
Sorry, but you are not running actual 4.6u as I can see from your print outs.
Please only use auto update.
thanks for helpingadmin wrote:Sorry, but you are not running actual 4.6u as I can see from your print outs.
I finally got the update 4.6u to install by reverting back to the old 2gig kingston usb stick . That is weird because it would not work before . I had reloaded the stick and all and had tried over and over to do updates but to no avail . That is when i bought a new 4 gig usb stick and reflashed the hardware . So I thought What the heck , I will try the old but updated 2 gig stick a try one more time . And bingo it accepted my id # and then I was able to update the 4.6u and it is running . All that is except the rain sensoris not reporting for some reason . So I suppose the new 4 gig stick is not any good ? Tim
[img][/Station 0 (TE-923): DORA WEATHER
Type # ID Name Last Signal Sensor Data
TS805 0 11 sec 2.7(2.7)m/s NNW
TS906 0 rain never -
TE923 0 11 sec 24.5° 30% 984.8mb (1021.4mb) fc:7
TS24C 0 11 sec 7.2° 59%
TS24C 1 11 sec 10.9° 49%
WindChill 9 11 sec 13.0°img]
