No internet access
oliverb
No internet access
Post by oliverb »
I have recently changed my router and just can't get internet access no matter what I try (my WAN IP says "no internet access").
I have enclosed screen dumps from my Meteohub ALIX1d and router BT Home Hub.
Edit I have updated the NETWORK screen image below to show my working settings.
YJB
Re: No internet access
Post by YJB »
Hmm, this can be anything.
Let's try a couple of things from the MH commandline:
Check your ip settings:
ifconfig eth0
Check your routing settings:
netstat -rn
Check your DNS setup
nslookup http://www.google.com
Check the path to the internet:
traceroute http://www.google.com
oliverb
Post by oliverb »
Hi thanks for the reply.
I have tried the commands but nothing comes back when I hit enter.
YJB
Post by YJB »
Hmm, sorry for not being clear, you are not supposed to type the "#". I use this as a prompt indicator for being root. I've updated the commands in the post above.
oliverb
Post by oliverb »
nslookup http://www.google.com reply server can't find http://www.google.com
traceroute http://www.google.com reply unknow host http://www.google.com
and a screen pic for the rest.
Regards.
oliverb
wfpost
Post by wfpost »
your meteohub screenshot telling an
IP: 192.168.1.68
but your router config screen says you assigned
IP: 192.68.1.69
for the meteohub
What now?
What is the IP config of the router. Does it have an IP: 192.168.1.254 ??
And if so,
what does a
ping 192.168.1.254
on the meteohub console show or bring up?
Or in other words.
Basic troubleshooting:
ping loopback ping 127.0.0.1
ping own IP-Address ping 192.168.1.68
ping gateway ping 192.168.1.254
ping external WAN-Address ping ...
ping external DNS-Server ping ...
the last two IP-Addresses you should get from your router.
DSL or PPPoE info ...
oliverb
Post by oliverb »
Sorry I changed my IP address since posting the pics to http://192.168.1.68/ . ping is 0.5ms.
Will it stop pinging or do I type a command to stop it?
wfpost
Post by wfpost »
with Linux you have to press CRTL-C to stop it
if the pings are all working, then it could be a DNS problem.
You could try using google´s DNS Server
change the DNS1 entry with meteohub from 192.168.1.254 to
8.8.8.8
oliverb
Post by oliverb »
ping loopback ping 127.0.0.1 OK
ping own IP-Address ping 192.168.1.68 OK
ping gateway ping 192.168.1.254 OK
ping external WAN-Address ping ... fail
ping external DNS-Server ping ...fail
wfpost
Post by wfpost »
if you ping the external WAN and DNS from a PC of your network.
Does this work okay?
(in theory ping replies could be blocked at the WAN and DNS Server)
Just as a test: Can you setup your meteohub to use DHCP, to see if this is working?
oliverb
Post by oliverb »
external WAN fails
external DNS OK
oliverb
Post by oliverb »
I have tried DHCP but this does not work. Gives the same problem "no internet".
YJB
Post by YJB »
As it looks right now, I tend to believe that there is a DNS issue.
Since you cazn post messages, I guess your PC is working fine. What is the DNS server that your PC is using, can you list the output of the following command:
On windows open a DOS box:
Start - Run - cmd - <enter>
ipconfig /all
oliverb
Post by oliverb »
Using ipconfig /all my DNS servers are listed as 192.168.1.254 and 192.168.1.254
wfpost
Post by wfpost »
I think, it´s not DNS-, but a router issue.
Although, if DNS is not working, meteohub wouldn´t find out the external WAN-IP.
Nevertheless the internet connection should work, because all IP-traffic is routed to the gateway address and your router then anyway must route those packets towards the WAN-LINK.
As the local pings work, I tend to say meteohub networking stack is okay.
Local gateway is reachable, but external WAN not respondinbg looks to me like the external traffic for meteohubs IP is somewhat broken or blocked.
Is the Firewall of the Router enabled? If so, could you disable it temporarily.
Normally only incoming packets are blocked depending on the firewall rules.
But maybe outcoming traffic is blocked somewhere with your firewall config.
