Problem Connecting To Network After Update
I just updated meteohub from version 4.7d to 4.7f and now I am unable to reconnect back to my network. I am using an ALIX 3D2. In the past I have had difficulty reconnecting back to my network after doing an update but never to this degree. I have tried rebooting my router numerous times along with powering off the ALIX and reconnecting power after waiting a few minutes. After two hours of trying to reconnect back to my network I am still unable to. Any help or suggestions would be greatly appreciated. Thank you.
Re: Problem Connecting To Network After Update
can you ping the box?
Finally, I was able to get my meteohub reconnected again. After unplugging the power and letting it sit for about 15 or 20 minutes I was able to get it to reconnect when I restored power. Any ideas why I am having this difficulty with reconnecting to my network after an update or reboot? Thank you.
could be a DHCP problem
either setup meteohub using a static IP-Address
or
if your router has the option with its DHCP Server for clients getting always the same IP-Address apply it
or
