Re: Weather34 TEMPLATE
ok go for that then . i will push the changes to github shortly .
- prestwickwx
OK. I think that will be a big help to the more casual viewer.
ok all pushed to GITHUB.
for users emailing for download password i have a large back log to work through Im not ignoring you, I will respond soon as I can..no need to send again .
Brian
Brian
- prestwickwx
Ok. Got it.weatherist34 wrote: Thu Sep 24, 2020 8:06 pm ok all pushed to GITHUB.
Brian
Looks great.
I have done a full download as I was away for a while and missed several updates.
Everything works fine, except a small issue: daily average wind direction doesn't display properly. It is a bit strange as I don't see this issue on other users templates. Any idea?
Thanks and once again congtats for all this job!
Alain
Alain
Meteo-Cugy (Switzerland, 705m)
http://www.meteo-cugy.ch
http://www.meteo-cugy.ch/Weather34-Auro ... /index.php
you need to run a firmware update to get the NEW api string for the today average wind direction .as per info page
*IMPORTANT
* METEOBRIDGE REBOOT REQUIRED NEW API VALUES ADDED(16th September 2020)
for others the final design for combined UV-solar and sun position was finished
simply looks this now with a softer contrast for light theme . the solar radiation live value is displayed in the relative indicator bar
have a great weekend ...
*IMPORTANT
Thank you, all is fine now.
- prestwickwx
I like the new UVI-Sun with the added text. There does seem to be a slight alignment problem. This is what I see in Chrome, Firefox and Edge on Windows. Looks fine on IOS.
Best Wishes,
Best Wishes,
should be ok now ...as usual sorry firefox etc checking fail !!prestwickwx wrote: Fri Sep 25, 2020 2:08 pm Hi Brian,
Best Wishes,
- prestwickwx
All fixed. Looks fine.
thank you more eyes the better ... I think it turned quite cool in the end , its good to listen to viewpoints always prompts a better result..have a great weekend ..
xray77
Hello Brian,
The colors in light mode of the new UV-Sun-Module looks much better now for me, so i have upgraded to the new one. Only one: the uv-risk text is not translated, due to not enough place i think so?
Many thanks for your work and a nice weekend!
regards
Mike
regards
Mike
I will try the translations later just tried to focus on color balance..let you know how it goes..xray77 wrote: Fri Sep 25, 2020 3:44 pm Hello Brian,
regards
Mike
minor adjustment only needed so should be ok . updated update file 26-09-2020 ive uploaded it now as im not here for the weekend .
xray77
Hello Brian,
Thank you for the superfast update! The translation looks better now, but actually i have 11:05 hours to sunrise (Sonnenaufgang), not sunset (Sonnenuntergang).. and 0 UV-I seems to be in original language "no risk". But there is absolutely no hurry to fix it!
Best regards and good relaxation,
Mike
Mike
- Bildschirmfoto 2020-09-25 um 20.10.03.png (101.38 KiB) Viewed 4320 times
