Page 81 of 102
Posted: Tue Sep 14, 2021 7:32 am
by weatherist34
glad that fixed it ..
*note to self always check Firefox because it does things different !
Download Update 14th September 2021
* (08:29) * Do NOT UPDATE if you are not using Davis Vantage Hardware !
* (08:29) * Corrects misalignment in charts in Firefox Ref Chuck.
- notes.png (243.26 KiB) Viewed 6088 times
Posted: Tue Sep 14, 2021 9:10 am
by jmontamat
Good morning, a small correction on the firerisk modules when the humidity is very high.
Posted: Tue Sep 14, 2021 9:36 am
by weatherist34
Good morning
no problem all fixed using if scenario
* (10:34) * Do NOT UPDATE if you are not using Davis Vantage Hardware !
* (10:34) * Fix negative firerisk value when humidity at 100% ref Josep.
- Screenshot at Sep 14 10-31-21.png (19.39 KiB) Viewed 6074 times
Posted: Tue Sep 14, 2021 10:26 am
by jmontamat
weatherist34 wrote: Tue Sep 14, 2021 9:36 am
Good morning
Quick, thanks
Posted: Wed Sep 15, 2021 11:26 am
by weatherist34
GITHUB users you will see this hope this explains what you are seeing
Download Update 15th September 2021
* (12:38) * Do NOT UPDATE if you are not using Davis Vantage Hardware !
* (12:38) * Update for ALT/OS Theme only
* (12:38) * Adds day averages/max values to top left of modules
- averages.png (267.64 KiB) Viewed 6027 times
Posted: Wed Sep 15, 2021 12:25 pm
by weatherist34
@all
Thank you for emails,pm etc and I do understand the disappointment but understand how disappointed I actually feel to read an email full of almost hateful rhetoric when numerous non Davis hardware owners unleash their frustrations on me without actually bringing anything to the table or leave no room for discussion. the endless bullshite how one is better than the other or some emails starts with “it’s unacceptable “ it works both ways but Im rather thicker skinned than some would like to imagine and I simply will hit where it hurts without engaging if it is unjustified ,thats why I've reverted to Davis hardware only support which is where I was back in 2018 which then was NANOSD only, so its not a new approach for those long term users..
I reiterate once again there are many alternative templates available via various forums just find one your comfortable with , one that meets your requirements and collaborate with whoever to perhaps improve or fine tune to your liking.
remember its free and i owe you nothing , you owe me nothing .if you put a price tag on your time then thats your problem..
brian ..
Posted: Wed Sep 15, 2021 12:28 pm
by jmontamat
Hi Brian I see it but not in the barometer mmHg.
Posted: Wed Sep 15, 2021 12:30 pm
by weatherist34
jmontamat wrote: Wed Sep 15, 2021 12:28 pm
ha the dreaded mmHG now there are two users
do it today sometime..b
Posted: Wed Sep 15, 2021 12:40 pm
by weatherist34
Josep should be ok now
- Screenshot at Sep 15 13-39-21.png (23.51 KiB) Viewed 6005 times
Posted: Wed Sep 15, 2021 1:47 pm
by jmontamat
Thanks, I no longer bother that I am going to the airport that the newlyweds are going to London.
Posted: Thu Sep 16, 2021 9:01 am
by weatherist34
Good morning
today I go sign for my boat so my mornings for the foreseeable future are taken up so hopefully the ALT/OS theme delivers some of those requests received .
it should resemble something like this if using a Vantage Pro2 plus setup .thanks for all input , ideas this week. some ideas just didn't work in design unfortunately it happens but sometimes revisiting the idea with some thought it materializes .
Download Update 16th September 2021
* (09:16) * Do NOT UPDATE if you are NOT using Davis Hardware !
* (09:16) * Update for ALT/OS Theme only
* (09:16) * Aligns all max/average values
* (09:16) * Adds solar max
"Uncle Albert"
- 1.png (152.21 KiB) Viewed 5956 times
- 2.png (206.8 KiB) Viewed 5956 times
Posted: Thu Sep 16, 2021 10:30 am
by weatherist34
Thought id share this Mac App
Plash I've been using for a few days basically allows you to convert your weather dashboard into a desktop wallpaper background .
the logic is quite simple simply add a url and the url then becomes a desktop permanently still with full access to desktop icons etc .
Its a
free App No Adverts or annoying monthly fees ,available on Mac app store
https://apps.apple.com/app/id1494023538 no idea if its backward compatible with older Mac OS .
you can disable it at anytime just accessing to the top toolbar icon .
- plash3.png (72.64 KiB) Viewed 5948 times
- plash.png (143.72 KiB) Viewed 5948 times
- plash4.png (181.04 KiB) Viewed 5945 times
Posted: Thu Sep 16, 2021 12:37 pm
by jasonmfarrow
Brian, alas PLASH only works on the very latest Mac OS 11 (I'm on Mac OS 10 because the podcasts app in MacOS 11 is shocking....)
Qq. Is it possible to put, in the console settings, options to choose the colours for temperatures (either #RGB or HSL) as input to the CSS?
Posted: Thu Sep 16, 2021 1:32 pm
by weatherist34
jasonmfarrow wrote: Thu Sep 16, 2021 12:37 pm
hello Jason not owning anything previous Mac OS versions installed,hence no idea if it’s compatible.
re colors its doable but its a tedious task and not sure of the wider audience will benefit, as above im picking up paper work for my boat i just bought later today,so much of my morning time for the foreseeable future which i tend too do template stuff is gone for a while to do anything you mentioned.im ok with adding small ideas ,fixes but your idea(s) could require some focus..
I meant to mention your ideas on colors for charts i didnt go ahead because need to match them to template modules that use a similar scheme . not in a position to do large scale changes because guarantee ill mess up somewhere
..that said feel free to make it a winter project for yourself be interesting to see the outcome .but please don’t distribute any updates would probably break them if there not implemented in the master.
Posted: Thu Sep 16, 2021 2:10 pm
by Gavsta40
Good evening Brian,
I'd just like to report an error after the last update - 16th September
The Davis Forecast module (weather34-davisforecast.php) icons have become out of place.
I have attached an image.
Cheers,
Gav.
