Re: Weather34 TEMPLATE
ok keep an eye on github later ill add it on to ev...its just a replica of davis script module..
weatherist34 wrote: Sun Oct 25, 2020 4:40 pm ok keep an eye on github later ill add it on to ev...its just a replica of davis script module..
Got it. Looks great! :D I didn't intend for you to have to do all the work - I was going to do a little customizing.
Thanks again and best wishes,
chuck do this
go to weather34.ev.php
edit the line at the top
change updaterhome to updaterhome-chuck
<?php
	#	TEMPLATE by BRIAN UNDERDOWN 2015-20
	#	CREATED FOR WEATHER34
	#   https://weather34.com/homeweatherstation/index.html
	#   https://www.weather34.com
include('livedata.php');
include('updaterhome-chuck.php');
Screenshot at Oct 25 21-06-42.jpg (89.67 KiB) Viewed 6317 times
weatherist34 wrote: Sun Oct 25, 2020 8:09 pm chuck do this
<?php
Ok. I have the second one. Working fine. :D I just need to include 0 (>=0) in my Davis Files because the AQI will frequently read 0 indoors.
Thanks again,
so lets attempt to make it look pretty :-) ...
Screenshot_2020-10-25 Weather34 EV Indoor Information.jpg (100.68 KiB) Viewed 6307 times
Got it. You changed the padding and added the Label. :D . Nice to have all of the Indoor data together!
if you want we can do this but think you were going to dump the weatherflow or give up on it ?? ..
Screenshot_2020-10-25 Weather34 EV Indoor Information(1).jpg (110.27 KiB) Viewed 6304 times
I am still using it until it plays out. At times it works fine and then there seems to be a WeatheFlow issue that rebooting repairs.
No need to go to a lot of trouble, but if you have the file already, it would be a nice option. I can always edit the custom updaterhome file. No hurry - almost sleep time for you.
Cheers,
ok no problem easy todo if you want it...just a couple of css lines... as for sleep kind of addicted to a program on discovery channel at the moment called street outlaws OKC 405 doesnt come on till 11:30..wife got me a farmtruck poster :D
there was a bad css bug in release earlier thanks to sean balfour for spotting it was in the solar radiation module the one used for those without a uv sensor..so update was downloaded..
(*Final-9.34z Update for 26th October 00:01)
* Final update for this version
* Contains fixes solar radiation module + bft alignment ref Sean Balfour
xray77
Post by xray77 »
I like the min/-Max-Values for the data's so much, this has been a wish of mine for a long time!
Great Update!
Is it possible to send me the indoor-module, cause it's broken or missing the graphics, i dont know why but is my fault..
Bildschirmfoto 2020-10-26 um 07.00.07.png (401.05 KiB) Viewed 6277 times
thanks and stay healthy!
best regards
Mike
good morning not sure what files you need is the indoor chart files ? i cant replicate this locally and not seeing this across many updated sites so something unique to you i guess. please send me an email not pm as i cant attach files via pm..i can send two chart files zipped up..
im off out for the day but i just added those files to update file so probably just easier for you to download the update and run it .also has a change to the average wind speed module to show 15 minute average as opposed duplicate wind description as its already outputted in the beaufort..have a good day..glad you like the final updated layout.. version 10 will be even more intuitive in terms of end user interface use and a lot slimmer ..
xray77
Post by xray77 »
Hello Brian,
Thank you, with the new update everything is as it should be! I guess I accidentally deleted an important file for the indoor graphics. As I said, that was my mistake.
Best regards have a nice day and stay healthy,
Mike
dc.kraft
Post by dc.kraft »
Hello everyone,
first of all many thanks again for the really successful LiveWeather..... sensational !!
Nevertheless I have a small topic....
unfortunately a bug has crept in with the last update from 26.10. ....
The display Beofourt is now completely in English again, apparently the German language has fallen out....
Greetings Dieter
dc.kraft
Post by dc.kraft »
dc.kraft wrote: Mon Oct 26, 2020 2:03 pm Nevertheless I have a small topic....
I have modified the data as much as possible, but I think that a small update is necessary.....
