weatherist34 wrote: Sun May 17, 2026 1:21 pm
Hello no problem but sure the old versions have no problems , only issue may be a future php update will break things .im aware of two issues on older versions that need some reworking in terms of php future releases . in short if aint broke don't fix it just carry on as you are ..Brian
Where can I find the latest version of the previous model?
I can download it and install it on my website.
Hi, Brian!
I'm having a display issue on my Iphone 15 PRO MAX. I've tried different browsers and haven't changed the scale on my phone. However, it works fine on my Ipad 13 M5 or PC.
*note as newer future Mac OS updates will no longer support Intel based apps I will only be able to develop with public PHP releases as my software does not support Beta versions of PHP only public releases unless I pay into another subscription (days are over where you could do one time purchases of software). So updates will be few and far between and very small mostly related to PHP as opposed to features.I purchased a new desktop Mac a couple months ago not thinking primarily about developing web stuff .Im not sure it would affect anything just lose the opportunity to be future proof confidently.
Alex im unable to reproduce this unless anyone else is experiencing the same I can't help. please provide a working url the browser source may help reveal the anomaly .see below using simulator I only have a 17 pro max to use locally or a simulator and can't replicate the appearance your seeing on either ...Brian
Screenshot 2026-06-22 at 07.32.23.png (32.43 KiB) Viewed 1700 times
Screenshot 2026-06-22 at 07.32.54.png (127.18 KiB) Viewed 1700 times
Screenshot 2026-06-22 at 07.39.00.png (1002.4 KiB) Viewed 1700 times
Hi, Brian! I figured out what the problem was: I had the "large" scale selected in my phone's settings (screen and brightness). So it's okay, it was my issue)
1.Verified for PHP 8.5.8 RELEASE
2.Minor change to realtime data module
3.Minor change to davis console forecast module
4.Windchill module phrase only present when below 5c or 41f will show persistent feel when above these values
Screenshot 2026-07-07 at 15.55.19.png (78.12 KiB) Viewed 1514 times
Screenshot 2026-07-07 at 15.49.38.png (97.4 KiB) Viewed 1514 times
Screenshot 2026-07-07 at 16.06.23.png (625.54 KiB) Viewed 1510 times
1.Minor change to Heat Index module where if greater than 32C/90F the caption reflects Heat Index or if below these values the word persistent feel will be displayed particularly beneficial for those who don't change module layout according to season i.e windchill and heat index
Screenshot 2026-07-25 at 07.02.25.png (1.08 MiB) Viewed 1346 times
1.cleans up heat index module code
2.cleans up windchill code
3.minor workaround change to end of day file based on users running 2 versions of template , using the original 2025 version and also 2026 version .the single path setup in meteobridge to drive both versions (ref Daniel)
Screenshot 2026-08-02 at 18.17.02.png (1.16 MiB) Viewed 1245 times
2.cleans up windchill module code (mk2 ref Geoff)
Screenshot 2026-08-03 at 07.48.54.png (1.17 MiB) Viewed 1221 times
weatherist34 wrote: Mon Aug 03, 2026 6:49 am
Where can I see this change in the setup or how do I use this change or improvement?
Torsten
Hello
No changes to be seen or required, in setup simply the end of day file reads the path or url you set in the setup screen to your mbrealtimeupload.txt . So if you run multiple versions of aurora it can use the meteobridge aurora output . Its a minor change nothing significant. Daniel was using two versions old and newer version the end of day file was scripted to use a simple path ../mbridge/MBrealtimeupload.txt now its uses whatever you set the path in the setup screen. Hope it makes sense if not have a large beer or two and just carry on using it …brian
