Hi there,
where can I change the background image of YoWindow 7 day forecast graphics?
in the file, wsDashYowindow.php I can not do the .
I also do not find where I can change the Yahoo Forcast ... there is still
Forcast for Leuven - Belgium
Ideea?
best regards herbert
Rasberry PI B und Huger WMR 928 Anleitung
kannschonsein
- Fresh Boarder
Re: Rasberry PI B und Huger WMR 928 Anleitung
In the script weather2/wsDashYowindow.phpkannschonsein wrote:Hi there,
The 4 different backgrounds are at line 32-35
#$yoLandscape = 'seaside'; // select the landscape by removing the commment mark # at one landscape only
$yoLandscape = 'oriental'; // put the comment mark # at the unwanted landscapes
#$yoLandscape = 'village';
#$yoLandscape = 'airport';The background you want to have should have NO # on the first position
At the moment the $yoLandscape = 'oriental'; is your choice
http://wiki.leuven-template.eu/doku.php ... irst#yahooI also do not find where I can change the Yahoo Forcast ... there is still Forcast for Leuven - Belgium
Ideea?
Which tells you to go to
==> https://weather.yahoo.com/germany/baden ... nn-658506/
if that is the correct Heilbronn
==> copy 658506 to your wsSettings.php
Succes, Wimbest regards herbert
kannschonsein
- Fresh Boarder
hello wim,
thanks
The Warning frame "No particular awareness of the weather is required. There are no Weather-warnings"
can I use the frame separately?
thanks
It is not really a frame but a separate script which can be used on a site, so also at yours.kannschonsein wrote:hello wim,
thanks
There are hundreds of users of this script on all kind of PHP/HTML websites.
Examples, download AND extensive documentation on http://www.weerstation-leuven.be/demowa ... arning.php
Succes, Wim
kannschonsein
- Fresh Boarder
Hello wim,
I think the page is now ready.
www.heilbronner-wetter.de
Once again many thanks for your help
greeting herbert
greeting herbert
