Page 2 of 2
Re: Raspberry WMR 928 Lauftext
Posted: Sat Nov 15, 2014 10:15 am
by wvdkuil
kannschonsein wrote:hi wim,
unfortunately that does not really know
http://www.heilbronner-wetter.de/wetter ... /index.php
the frame is not displayed on the left, I can adjust the frame (php)?
I use Web to date 8 and have never left but it does not work.
do you have an idea?
This is a CSS "problem".
The path to the iframe goes:
body => main => mainbox => content => the iframe without a name
main is set in the css to be 100% wide => OK
mainbox is set in css to
#mainbox {
width: 960px;
padding: 20px 0;
margin: 0 auto;
which specifies the width of the mainbox (960 px), the margin (0px) and that the mainbox should be centered (auto).
Then the content is set to always be at the right (float:right) and be only 680px wide.
#content {
float: right;
width: 680px;
And in that 680px wide content you are putting an iframe with settings:
<iframe src="http://heilbronner-wetter.de/weather2/index.php?p=10&lang=de&ipad" height="1000" width="180%" frameborder="0" scrolling="no" align="left">. .. . </iframe>
So the wide of the iframe is set to 180% = 1,8 * 680 = 1224 pixels and will extend to the right outside your main page.
The real contents of the iframe is 1100px so the remainning 114 px is to the left / right of the index.php you are displaying inside the iframe.
I made a screenshot to explain a bit as it is difficult to explain in "my" English.
Posted: Sat Nov 15, 2014 12:32 pm
by wvdkuil
@kannschonsein
To make life a little easier I enclose a modified index.php
1. make a backup of the weather2/index.php
2. unzip and upload the new index.php to weather2/
When you now use a template page with &ipad it will always fit exactly in the enclosing iframe or browser.
As long as the iframe is at least 800px.
If you want a smaller iframe, modify line 24 in weather2/styleMain30.css
from
	min-width: 800px;
to
/*	min-width: 800px;	*/
example:
normal page: http://www.weerstation-leuven.be/weathe ... 11&lang=en
adaptable page: http://www.weerstation-leuven.be/weathe ... ng=en&ipad
Works far better than doing the calculations.
Posted: Sun Nov 16, 2014 10:04 am
by kannschonsein
good Morning,
I think I'm on the right way
Posted: Sun Nov 16, 2014 10:37 am
by wvdkuil
kannschonsein wrote:good Morning,
1. I do not understand: what is the problem with the image ?
2. You should replace the weather2/index.php as explained in viewtopic.php?f=60&t=10021&p=16421#p16418
So make a copy of weather2/index.php, unzip the attachement to that post, and upload it to your weather2/ folder.
Than the width of all pages will fit exactly inside the area you define.
Posted: Sun Nov 16, 2014 11:17 am
by kannschonsein
its all ok and it works just fine
I mean if you frame the weather warning separately
can use as the other pages with &ipad also
