Weatherstation Lufft WS600 **solved**
The_Weatherman
Re: Weatherstation Lufft WS600
Post by The_Weatherman »
Thank you very much! It works very well!
The_Weatherman
I have also a Ultrasonic Anemometer from Gill which measures windspeed, direction, temperature, humidity and pressure. Is it interesting for you to integrate it into your Meteohub Software?
Sounds interesting! How can that be connected on a physical layer?
If it translates somehow to RS232/USB I can try to make a driver for it.
In order to do so it needs to be connected to your Meteohub and
remote access to the system by me on ports 22 and 7777.
The_Weatherman
It can be connected at the same way like the Lufft weatherstation. These professional stations mostly have a rs485 interface. I use a rs485/232 converter e.g. from ADAM. Oher converters from Phoenix Contact and so on work too.
You also can connect the stations by a W&T Com-Server via TCP/IP. On Windows System you can create a virtual COM Port to connect the Station, maybe its on Linux possible too.
Let me know what is the best for you. I can realize the serial or the TCP/IP way of connection.
Easiest way would be to connect it also to your Meteohub (serial) and
to give me access to your Meteohub on ports 22 and 7777.
Then I can test the drivers directly on your rig.
The_Weatherman
Ok, please give me a few days so that i can prepare the system. I give you an info when its running.
Please lets close the thread here and send details regarding your Gill setup to "info(at)meteohub.de".
