MeteoBridge Stops Logging **solved**
blacklistedcard
- Junior Boarder
Re: MeteoBridge Stops Logging
Should I try and plug in a USB powered HUB? I have the MeteoStick plugged directly into the usb port on the D-LINK DIR-505. With a usb cable of about 2.5 meters.
I guess the long cable is the problem. Trying a hub might be an option to go with.
Never tried operating with cables above 1m myself.
blacklistedcard
- Junior Boarder
Ok... Let me try some things and I'll get back to you on the progress.
blacklistedcard
- Junior Boarder
Further testing results.
a) Used a shorter USB cable with the MeteoStick. ==> Logging died after a couple of hours.
b) Plugged the MeteoStick directly into the D-LINK DIR-505 REV. A1 device ==> Logging died after a couple of hours.
c) Move the D-LINK DIR-505 REV. A1 to a different plug. I have hospital grade plugs installed in my house. Maybe the additional EFI/CFI filtering is having a problem? I'll move it to a standard plug.
- 8280-I.jpg (9.44 KiB) Viewed 6514 times
When I get it right, the root cause was reduced to a faulty Meteostick which is now being replaced. Let's see if the prblems do diasappear by that (which my guess is).
blacklistedcard
- Junior Boarder
Re: MeteoBridge Stops Logging **solved**
So you think the MeteoStick is faulty?
If you are not the customer I had a similar email exchange on this, I think I messed that up.
Too many mails and sometimes not that easy to link forum postings with pms.
However, if you allow me to login remotely, I can check if the meteostick is the problem.
Can you please send me dail-in details again, to "info(at)meteobridge.com".
blacklistedcard
- Junior Boarder
Email sent with the details to login
blacklistedcard
- Junior Boarder
So far the most I can get it to log is about 4-5 hours.
PatrickTraugott
- Fresh Boarder
There is connectivity issue. So check it and reboot the process.
Kamagra http://www.dragonapotheke.com/
blacklistedcard
- Junior Boarder
I just rebooted it. I also just attached a power USB hub to the MeteoStick and the Dlink router. Let's see if the extra juice of the USB hub makes a difference.
