Page 2 of 2
Re: ASUS WL-330N3G Not Loading **solved**
Posted: Wed Dec 26, 2018 9:48 pm
by oturn
admin wrote: Sun Dec 23, 2018 12:25 pm
Sorry for the hassle.
Stuff happens. Thank you for the fantastic support and product.
Posted: Mon Dec 31, 2018 9:41 am
by redawg
So is the only solution to reflash the whole device?
Posted: Tue Jan 01, 2019 4:30 pm
A power cycle should do. If not you might need to clear the overlay file system (which is equivalent to revert to factory defaults) which might be most easily done by reflashing or using openwrt "reset" function.
"Network" tab -> Expert Mode -> login as root with your standard password -> "System" tab -> "Back / Flash Firmware" tab -> Reset to defaults
