Upload to meteotemplate
Re: Upload to meteotemplate
I think it is the harsh SSL encryption enforced by your sever, which results into may rounds of trying until an agreement has been reached.
staze
Post by staze »
My meteotemplate connection isn’t using ssl/https...
staze
Post by staze »
it's timing out when it's doing the actual DB insert (given the timestamps and my MT settings being every 5 minutes)
2019-04-15 12:45:44 Error: 2019-04-15 12:45:31 Read error (Operation timed out) in headers. (no more tries)
2019-04-15 12:40:39 Error: 2019-04-15 12:40:25 Read error (Operation timed out) in headers. (no more tries)
2019-04-15 12:35:14 Error: 2019-04-15 12:35:01 Read error (Operation timed out) in headers. (no more tries)
2019-04-15 12:30:16 Error: 2019-04-15 12:30:00 Read error (Operation timed out) in headers. (no more tries)
2019-04-15 12:26:08 Error: 2019-04-15 12:25:53 Read error (Operation timed out) in headers. (no more tries)
2019-04-15 12:20:46 Error: 2019-04-15 12:20:31 Read error (Operation timed out) in headers. (no more tries)
2019-04-15 12:15:42 Error: 2019-04-15 12:15:28 Read error (Operation timed out) in headers. (no more tries)
2019-04-15 12:10:43 Error: 2019-04-15 12:10:28 Read error (Operation timed out) in headers. (no more tries)
2019-04-15 12:05:33 Error: 2019-04-15 12:05:18 Read error (Operation timed out) in headers. (no more tries)
2019-04-15 12:00:29 Error: 2019-04-15 12:00:14 Read error (Operation timed out) in headers. (no more tries)
2019-04-15 11:55:16 Error: 2019-04-15 11:55:02 Read error (Operation timed out) in headers. (no more tries)
2019-04-15 11:50:15 Error: 2019-04-15 11:50:00 Read error (Operation timed out) in headers. (no more tries)
Can you please give me a remote login? Please send credentials to "indo(at)meteobridge.com".
staze
Post by staze »
sent this morning (local time).
Timeout is 13 seconds. Most time the upload just takes a second, but here and there it times out. Looks like the receiving process on the server gets sometimes stalled or massively delayed. I would recommend to add timing information there and to find a correlation between time outs and server operations.
staze
Post by staze »
That is so weird. It's only on the DB update times (the 5 minute intervals). But an insert should happen pretty quick (it's innodb, so there's no need to lock the table or the whole db).
Weird. alright, will see if I can add some logging to see how long the insert is taking. I'm not entirely convinced MT isn't just not responding (and MB is timing out on that).
Wish MT dev was better able to help. Could be some PHP plugin causing an issue, etc.
A dead lock situation where the update process and scheduled database process do block each other would be the best explanation. Do you have a chance to monitor database operations in that regard?
staze
Post by staze »
not that I know of, but I have been meaning to see if I can enable slow queries. That might show what's going on... might.
again, the data gets inserted. and the API log from MT looks fine. either it's just not responding (and MB times out waiting for a response) or for some reason the insert is just taking too long.
So, it JUST did an insert, here's what MT says:
End time for database update based on timestamp of first cache data: 2019-04-19 17:10:47
Rounded end time for database update: 2019-04-19 17:15:00
Time to update the database, preparing query.
Timestamp first cached record: 2019-04-19 17:10:47
Timestamp last cached record: 2019-04-19 17:14:55
Timestamp last received record: 2019-04-19 17:15:56
Timestamp new database record: 2019-04-19 17:15:00
No new day, currentRain=0.00
The database is updated with the following query:
            INSERT INTO alldata
            (DateTime,T,Tmax,Tmin,H,P,W,G,B,R,RR,D,A)
            values ('2019-04-19 17:15:00',62.1,62.2,61.9,78.0,29.89,6.0,14.1,314,0.00,0.00,55.1,60.3
Cache file deleted.
Saving first new data to cache/apiCache.txt, timestamp=2019-04-19 17:15:56
Generating log file cache/apiLog.txt
And MB says:
2019-04-19 17:16:10 Error: 2019-04-19 17:15:56 Read error (Operation timed out) in headers.  (no more tries)
So times align. I need to figure out if I can easily log how long the insert takes. That said... MT is using the date as the primary key, which I don't think is correct for DB design (and InnoDB apparently hates it from googling around). I bet if I converted the DB back to MyISAM it would fix it, but I don't want to do that.
Here's original DB creation from MT:
CREATE  TABLE  `$dbName`.`alldata` (  `DateTime` datetime NOT  NULL ,
	 `T` decimal( 4, 1  )  DEFAULT  NULL ,
	 `Tmax` decimal( 4, 1  )  DEFAULT  NULL ,
	 `Tmin` decimal( 4, 1  )  DEFAULT  NULL ,
	 `H` decimal( 4, 1  )  DEFAULT  NULL ,
	 `D` decimal( 4, 1  )  DEFAULT  NULL ,
	 `W` decimal( 4, 1  )  DEFAULT  NULL ,
	 `G` decimal( 4, 1  )  DEFAULT  NULL ,
	 `B` decimal( 4, 1  )  DEFAULT  NULL ,
	 `RR` decimal( 7, 3  )  DEFAULT  NULL ,
	 `R` decimal( 7, 3  )  DEFAULT  NULL ,
	 `P` decimal( 7, 3  )  DEFAULT  NULL ,
	 `S` decimal( 5, 1  )  DEFAULT NULL ,
	 `A` decimal( 4, 1  )  DEFAULT NULL ,
	 PRIMARY  KEY (  `DateTime`  ) ,
	 UNIQUE  KEY  `DateTime` (  `DateTime`  )
	  ) ENGINE  =  MyISAM  DEFAULT CHARSET  = utf8 COLLATE  = utf8_unicode_ci;
Okay, I'm going to play with server side (DB) and see what I get.
