Purpleair sensor integration - need help. **solved**
Kanok
Re: Purpleair sensor integration - need help. **solved**
Post by Kanok »
New build has released "Meteobridge 5.0 (Dec 1 2020, build 1475), FW 1.3 " It fixed the problem for me.
Ambient Weather WS-1900
WUnderground, PWS - IPATHUMT2
CWOP - EW4214
http://kanok.net/pws
ice124
Post by ice124 »
The new build Meteobridge 5.0 (Dec 1 2020, build 1475), FW 1.3 fixed this issue for me, as well.
garybridge
Post by garybridge »
This is working well for me also, I have also retrofitted the BME680 sensor to give VOC readings, would it be possible to include this?
Gary
Gary Bridge MIET, MIPS.
garybridge wrote: Wed Dec 09, 2020 6:03 pm This is working well for me also, I have also retrofitted the BME680 sensor to give VOC readings, would it be possible to include this?
We cannot support home-brew sensor solutions, but you can write an individual plugin for this.
garybridge
admin wrote: Fri Dec 11, 2020 2:00 am
Thank you for your reply, re Plug-ins
FYI It isn’t a home-brew it is direct from PA themselves but admittedly still in trial, the retrofit is just replacing the existing temp humidity sensor with the 680. At the moment it is working in Brian’s Weather 34 template.
