Meteobridge pro automatic reboot
ruzzi.f@gmail.com
Re: Meteobridge pro automatic reboot
Post by ruzzi.f@gmail.com »
Can you please support me with this issue?
I tried to put an old firmware version (4.0) and seems it works fine. So should be some firmware update issue.
ruzzi.f@gmail.com wrote: Thu Sep 02, 2021 9:54 am Upload StatusRaw Sensor DataMin/Max Data
Live Data
# Sensor Signal Metric Data Imperial Data
0 Outdoor 4s -83db 23.5°C 65% (dew 16.5°C, heat 23.5°C) 74.3°F 65% (dew 61.7°F, heat 74.3°F)
0 Wind 1s -83db 2.4m/s (avg 2.9m/s) 334° NNW 5.4mph (avg 6.5mph) 334° NNW
0 Rain 1s -83db rate 0.0mm/h rate 0.00in/h
0 Indoor 34s 71.4% 47.4°C 18% 1021.6hPa (1021.6hPa) 117.3°F 18% 30.17inHg (30.17inHg)
9 Data #10 27 sec 10% system load 10% system load
9 Data #11 27 sec 47.2h uptime 47.2h uptime
9 Data #12 27 sec 7% data store usage 7% data store usage
9 Data #13 27 sec 69% RAM usage 69% RAM usage
9 Data #15 27 sec 50 processes 50 processes
9 Data #16 27 sec 2sec since last data 2sec since last data
9 Data #14 27 sec 1.93W power 1.93W power
9 Data #17 27 sec 5.47V voltage 5.47V voltage
9 Data #18 27 sec 0.35A current 0.35A current
9 Data #19 27 sec 25.2MB tx data 25.2MB tx data
9 Data #20 27 sec 26.1MB rx data 26.1MB rx data
9 System #9 27 sec 53.6°C 13% 1021.9hPa (1021.9hPa) 128.5°F 13% 30.18inHg (30.18inHg)
RF signal level is rather low (-83db). You will need to open up to the maximum recommended -90db as Rf threshold to get data in. If RF further degrades by humidity in the air, cold batteries, etc it might loose connection here and there. Do you have a chance to reposition the MB in the room to get better signal strength?
ruzzi.f@gmail.com
83db is on second mb where I did set sensitivity to 90 db and it is working quite well.
The mb where I have big issues is the one where isgnal is very strong around 60 db
Neverthless the logger restart continuously, can you explain me why? (considering also that I have flaged the item to avoid logger restart in case of missing signal)
ruzzi.f@gmail.com
the storage says there are 7gb of memory. is it normal? other mb says 1gb (should be correct storage)
why? are there mb with 7gb?
Can you please share a screen dump of "system-info" page?
ruzzi.f@gmail.com
Platform: Meteobridge PRO
RAM: 61500 kB total, 9140 kB free (85% used)
Storage Intenso: Internal 7.0 GB total, 6.8 GB free (3% used, 661.8 yrs)
SW Version: Meteobridge 5.2 (Sep 10 2021, build 14566), FW 1.4
Uptime: 10 hours, 51 minutes Buffer: 1 items (0%)
Power Data: 5.51V 355mA 1.95W (Box Climate: 59.1°C 14%)
Network
MAC: C4:93:00:06:79:0C
LAN IP: 192.168.1.145 WLAN IP: --
LAN Mask: 255.255.255.0 WLAN Mask: --
Gateway: 192.168.1.1 TX Traffic: 4.0 MB
DNS: 151.5.216.150 RX Traffic: 17.6 MB
WAN IP: 91.254.137.82 Provider: Wind Tre S.p.A.
Localization
Location by IP: Italy / Lazio / Rome
UTC: 2021-09-11 12:51
Local Time: 2021-09-11 14:51
Timezone: Europe/Rome
Latitude: 42.248943
Longitude: 14.513191
Problem is the Intenso USB stick which has shown a tendency to fail after a couple of years. Since many years we just ship MB PROs with SLC USB sticks from ATP with 1 GB in size.
Would you feel fine to replace the stick? Please see a video here: https://www.youtube.com/watch?v=Wn0_tM_jjZI
Where are you located?
ruzzi.f@gmail.com
I am located in Italy
65126 Pescara
I can send you a new stick, if your are fine with replacing yourself. Linked video explains how to do it.
Please mail to "info(at)smartbedded.com"
ruzzi.f@gmail.com
ok, I have 3 MB pro
Will ship on Monday.
