I have installed on Weather Display the console WMR89
mentions it here as well "the OS WMR100,WMS200/300/WMR88/WMR180/WMR89 USB "
https://www.weather-display.com/supported.php
Oregon WMR89A and meteobridge
Re: Oregon WMR89A and meteobridge
The console is fully functional in windows.
See that there is an entry for it in the device manager
The console has drivers for windows 7, 8 and 10
- wmr89a.jpg (60.57 KiB) Viewed 12531 times
- wmr89.png (57.68 KiB) Viewed 12531 times
Ok convinced and confused
Can you please tell me USB vendor and product ID? It should be somewhere in the Windows settings.
I found a WMR89 in my shack of obsolete HW, connected it and I the same issue as zakos52. The station is not recognized on PRI but it is on the Meteobridge PRO and PRO2. I don't understand the logic behind this, but will try to dig deeper. Sorry to zakos52 that I was a non-believer.
I found on the internet here https://groups.google.com/g/weewx-user/ ... 2MgM?pli=1
that in Rpi 3 it works normally, while in Rpi 4 some changes must be made in some file.
I hope this helps
I hope this helps
Good evening, Happy New Year
Can you let me know if the station WMR89A will be able to work on Rpi 4 in any upgrade?
Good evening,
I tried a few things but it does not work on RPI 4. Sorry.
I had a hope, but...
Yes, but the station has been discontinued in 2018! May be time for a HW update?
WMR89a has been a problem child from the beginning as they use non-standard baud rates that the Linux drivers don't support unless doing some magic/patches around this.
