Oregon WMR89A and meteobridge
zakos52
Post by zakos52 »
I'm trying to connect the Oregon WMR89A weather station to meteobridge, running on an RPi 4 with 4GB RAM without success.
In meteobrige the connection is as follows
Primary Station : meteostick Vantage Vue
Station 1: Air Link
Station 2: PurpleAir
Station 3: WMR89
With Connection: USB Serial and Device: /dev/ttyMH or /dev/ttyMH014 no station works!
If I select Connection: Serial and /dev/ttyS0 the original stations work but not the WMR89A!
The WMR89A console is connected to one USB 2.0 port of the RPi 4 and the meteostick is connected to the other USB 2.0 port.
On the RPi 4 there are still 2 free USB 3.0 ports
Am I doing something wrong with the connection?
Is there any other way to get the WMR89A console to work?
SW Version: Meteobridge 5.8 (Dec 16 2023, build 3110), FW 1.3
Raspberry Pi 4 Model B
Re: Oregon WMR89A and meteobridge
Both USB 2.0 ports of the RPI 4 are expected to work.
Can you give me remote access with the WMR89 connected to one of the USB 2.0 ports?
Please send credentials to "info(at)meteobridge.com".
zakos52
Post by zakos52 »
I sent the credentials to the e-mail
Thanks, I can login. When inspecting the connected USB devices there is no WMR89 in sight.
Please see below, only the FTDI converter of Meteostick is recognized. Are you sure you currently have the WMR89 connected to one of the USB connectors? It should at least show up as USB device. BTW: It looks like you can use USB 2.0 and USB 3 ports.
root@MeteoBridge:~# lsusb
Bus 001 Device 004: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@MeteoBridge:~# ls -la /dev/ttyUSB*
crw-rw----    1 root     dialout   188,   0 Dec 18 13:31 /dev/ttyUSB0
root@MeteoBridge:~# ls -la /dev/ttyMH*
lrwxrwxrwx    1 root     root            12 Dec 18 12:56 /dev/ttyMH -> /dev/ttyUSB0
lrwxrwxrwx    1 root     root            12 Dec 18 12:56 /dev/ttyMH014 -> /dev/ttyUSB0
root@MeteoBridge:~#
I tested with two USB devices on my RPI 4 and it looks fine.
root@MeteoBridge:/# lsusb
Bus 001 Device 005: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
root@MeteoBridge:/# ls -la /dev/ttyUSB*
crw-rw----    1 root     dialout   188,   0 Dec 20 16:45 /dev/ttyUSB0
crw-rw----    1 root     dialout   188,   1 Dec 20 16:45 /dev/ttyUSB1
root@MeteoBridge:/# ls -la /dev/ttyMH*
lrwxrwxrwx    1 root     root            12 Sep 16 14:18 /dev/ttyMH -> /dev/ttyUSB0
lrwxrwxrwx    1 root     root            12 Dec 20 16:45 /dev/ttyMH011 -> /dev/ttyUSB1
lrwxrwxrwx    1 root     root            12 Sep 16 14:18 /dev/ttyMH012 -> /dev/ttyUSB0
zakos52
Post by zakos52 »
Did you add wmr89 as a fourth weather station?
what else do you want me to do?
Linux shell tells me via "lsusb" that the WMR89 is not connected. When you connect it, I can continue.
zakos52
Post by zakos52 »
As I wrote, the WMR89 is connected to one of the two ports USB 2.0
You want me to connect it to a port USB 3.0?
The RPI does not see it, please try on USB3 ports.
Are you sure the WMR89 works at all? If the device is not showing up on the RPI at lowest interface level, that indicates that there is something wrong hardware wise.
zakos52
Post by zakos52 »
Τhe Console displays the data from the sensors normally.
I will plug it into the USB 3.0 port and update right away!
zakos52
Post by zakos52 »
The console works normally at windows 10.
I have added WMR89 as station 3.
1. With connected "USB Serial" , only the two air quality sensors are displayed and not the main station Vantage Vue and WM989.
2. with connection "Serial" , the main station is displayed together with the air quality sensors, but not the WMR89!
3. The console is now connected to the port USB 3.0
Still no sign of a connected WMR89 on HW level.
As long as it is not registered on your RPI4 as an USB device at all, any settings on Meteobridge level are useless.
First entry is the Meteostick, other three entries are USB hubs onboard of the RPI. No cp210x device that WMR89 normally offers.
I hardly doubt that you get any data out of this WMR89 console with any computer. The interface remains dump.
zakos52
Post by zakos52 »
That is, the problem is detected in the Rpi 4 and not in the meteobridge?
What should be done in your opinion for it to be recognized by the Rpi 4 the console WMR89?
The problem is that it is NOT detected on the PRI operating system (running openwrt). It is not an issue with Meteobridge software or cp210x kernel drivers.
As said, I do not believe you can get data out of this specific station with any PC. It looks defective/disfunctional to me.
There is nothing I can do here.
zakos52
Post by zakos52 »
Any other version of linux ιn combination with meteobridge could detect WMR89?
Anyway, in windows 10 the console is fully functional!
Thank you very much for your time
zakos52 wrote: Wed Dec 20, 2023 11:22 pm Any other version of linux ιn combination with meteobridge could detect WMR89?
No, I don't think so, the USB port of WMR89 is dead IMHO.
zakos52 wrote: Wed Dec 20, 2023 11:22 pmAnyway, in windows 10 the console is fully functional!
Hard to believe from my experience, but you will know better.
Sorry, that I could not help you.
