Seems I cannot reach my Davis VP2 anymore (after MB update?)
zaric
Re: Seems I cannot reach my Davis VP2 anymore (after MB update?)
Post by zaric »
Hi
I disassembled the MB pro, the USB key is an ATP NanoDura industrial only 1 GB. I replaced it with the same model but the problem remains exactly the same !
The original USB key was not formatted, so I formatted it on my PC and it seems to work fine.
I've also tested with no key plugged in, the new key in the front USB port, and another key in the internal and front ports, in all cases the result is still the same. On startup, the MB Pro screen always displays : Format failed
zaric
Post by zaric »
Hi
I disassembled the MB pro, the USB key is an ATP NanoDura industrial only 1 GB. I replaced it with the same model but the problem remains exactly the same!
This one is becoming one for Boris when he gets a chance?
zaric
Post by zaric »
I'm sorry, but I don't understand your answer. I don't know any Boris.
zaric wrote: Wed Apr 16, 2025 10:12 pm I'm sorry, but I don't understand your answer. I don't know any Boris.
Boris is the Meteobridge developer and Admin on this board and will know what or be able to determine what this exact issue is all about.
zaric
Post by zaric »
Ok, thanks for your help.
And Boris will contact me?
He frequents the forum and he should pick this up in due course.
Looks very much like a USB hub chip failure and as a result USB storage can not longer been reached.
Can you please provide me remote login, so that I can verify this assumption? Please send credentials to "info(at)meteobridge.com".
zaric
Post by zaric »
did you receive my remote login ?
