Page 2 of 2
Re: Seems I cannot reach my Davis VP2 anymore (after MB update?)
Posted: Wed Apr 16, 2025 6:53 pm
by zaric
Hi
I disassembled the MB pro, the USB key is an ATP NanoDura industrial only 1 GB. I replaced it with the same model but the problem remains exactly the same !
The original USB key was not formatted, so I formatted it on my PC and it seems to work fine.
I've also tested with no key plugged in, the new key in the front USB port, and another key in the internal and front ports, in all cases the result is still the same. On startup, the MB Pro screen always displays : Format failed
Posted: Wed Apr 16, 2025 6:54 pm
by zaric
Hi
I disassembled the MB pro, the USB key is an ATP NanoDura industrial only 1 GB. I replaced it with the same model but the problem remains exactly the same!
Posted: Wed Apr 16, 2025 9:50 pm
by Mattk
This one is becoming one for Boris when he gets a chance?
Posted: Wed Apr 16, 2025 10:12 pm
by zaric
I'm sorry, but I don't understand your answer. I don't know any Boris.
Posted: Wed Apr 16, 2025 10:31 pm
by Mattk
zaric wrote: Wed Apr 16, 2025 10:12 pm
Boris is the Meteobridge developer and Admin on this board and will know what or be able to determine what this exact issue is all about.
Posted: Thu Apr 17, 2025 12:27 am
by zaric
Ok, thanks for your help.
And Boris will contact me?
Posted: Thu Apr 17, 2025 1:37 am
by Mattk
He frequents the forum and he should pick this up in due course.
Posted: Mon Apr 28, 2025 11:52 am
Looks very much like a USB hub chip failure and as a result USB storage can not longer been reached.
Can you please provide me remote login, so that I can verify this assumption? Please send credentials to "info(at)meteobridge.com".
Posted: Sat May 03, 2025 8:10 pm
by zaric
did you receive my remote login ?
