Feature Request FTPS with Passive mode
zakos52
Re: Feature Request FTPS with Passive mode
Post by zakos52 »
Since the RPi3 and RPi4 devices are more powerful and do not face memory problems, in order to be able to utilize them as best as possible,
could there be a version of meteobridge only for RPi devices that supports in addition to FTP and the FTPS protocol in the future?
I am waiting for a response from the meteobridge developer
zakos52 wrote: Sat Sep 13, 2025 2:10 pm Since the RPi3 and RPi4 devices are more powerful and do not face memory problems, in order to be able to utilize them as best as possible,
The answer is that I don't have it on my todo list, because I do not intend to further split development branches for the various platforms. FTP and SFTP are good options. Please make your peace with it.
zakos52
Post by zakos52 »
…FTP and SFTP are good options. Please make your peace with it.
I changed hosting and went to another one that supports the SFTP protocol!
I entered the settings that the provider gave me (image)
When I click Test SFTP nothing happens and after a while the meteobridge page disappears and a white page appears that says “BAD GATEWAY”
I tried with Putty, FileZilla, WinSCP and I connect normally!
Not with meteobridge
What am I doing wrong?
Postscript
After I set up the SFTP settings, why does the upload status say it's trying to connect to FTP?
Platform: Raspberry Pi 4 Model B Rev 1.1 Rev 1.1
RAM: 3895 MB total, 3743 MB free (3% used)
Storage: ATP SLC, 1.5 GB total, 724 MB free (53% used, 254.2 yrs)
SW Version: Meteobridge 6.2 (Sep 23 2025, build 4119), FW 1.3
You are still on FTP, not SFTP (as I can see from the error message naming ncftpput).
At least sharing the used host URL would be helpful.
zakos52
Post by zakos52 »
The settings I need to set from the provider that hosts my page are
Host: sftp://ftp.meteovyronas.gr
Port: 2234
The message from meteobridge is
Error: SFTP test upload failed: /usr/bin/ssh: Connection to
******@sftp:22 exited: Connect failed: Error resolving 'sftp' port '22'. Name does not resolve
The option "Test Proxy-SFTP"
displays the message
Error: Proxy-SFTP test upload failed: Error: SFTP connect to sftp://ftp.meteovyronas.gr via port 2234 failed.
That is, meteobridge does not see port 2234?
It only sees ports 21 and 22?
Can the problem be resolved in the next upgrade?
zakos52 wrote: Fri Oct 10, 2025 3:51 pm The option "Test Proxy-SFTP"
This is getting a bit long in the teeth. SFTP and Proxy-SFTP work fine for tons of users, there is nothing to be fixed. Most common error is to specify a path that does not exist.
I was able to fix those typical user errors by remotely logging in on their Meteobridge and setting it up correctly. When you have the needed trust, please send credentials to "info(at)meteobridge.com". I am 100% sure Meteobridge can do SFTP uploads to any SFTP supporting web hoster.
zakos52
Post by zakos52 »
I sent the credentials to "info(at)meteobridge.com".
zakos52
Post by zakos52 »
I sent a new email to "info(at)meteobridge.com"
