Page 2 of 2
Re:ALIX.1D pros amd cons
Posted: Sat Nov 28, 2009 5:10 pm
by skyewright
A very interesting link. Thank you.
N.B. That UPS design would need some adaptation for an ALIX-1D as the 1D takes a 12V power supply rather than 18V.
Posted: Sat Nov 28, 2009 7:43 pm
by oliverb
Thanks for that netsigi.
I have plenty of space next to my main PC.The larger case will fit in better and gives me more options for my custom PSU/charger.
The PSU is not the problem it is the backup battery that takes up all the space. I plan to run my WMR928 and ALIX-1D off the same supply so I can get rid of the WMR928 PSU unit and battery back up both.
I will probably have a power connection for the WMR928 on the back of the ALIX case. I may also add a power and activity LED as well so I know the unit is working. The case has these built in and should work from the supplied header plug.
If I get it working I will post the details on this forum.
Posted: Sun Nov 29, 2009 5:33 pm
by netsigi
I always forget : I have many WRAP's and ALIXes, but i newer needed one with vga. I use a 3d2 for meteohub.
