ALIX.1D pros amd cons
oliverb
Post by oliverb »
I have been thinking about the ALIX.1D from http://shop.varia-store.com/product_inf ... IX-1D.html
preconfigured for 199 euros.
I have a WMR928 so I presume it will connect into the ALIX.1D serial port without the serial adaptor I use on my NSLU2?
I see it uses CF cards but are these reliable?
Size is not a problem but what are the pros and cons compared to the other Meteohub hardware?
Any info would be appreciated.
Brett.
Re:ALIX.1D pros amd cons
To my knowledge the ALIX systems are very reliable. CF card varia-store bundles with it is a top notch SLC based card (which makes it a bit more expansive). all in all ALIX is a much more reliable platform than NSLU2.
As ALIX can be bought from European sellers at a reasonable price, I personally would prefer it compared to eboxes which are harder to get and provided with a hefty uplift here in Europe.
For non-European users, eboxes might be more interesting as uplifts are the other way round.
P3R
Post by P3R »
oliverb wrote:I have a WMR928 so I presume it will connect into the ALIX.1D serial port without the serial adaptor I use on my NSLU2?
Yes, that's what I use and it works great.
oliverb
Post by oliverb »
Thanks for your prompt replies.:)
Brett.
AAMFlyer
Post by AAMFlyer »
I never tried the 1D but didn't have a good experience with the 3D2 on 2 different ones....I think I ended up having static electricity problems.....
Anyway for what it's worth....I got two Ebox 4300's here in the US and so far they are rock solid for me..... I have 2 running and one is in a remote shed with what I would call a harsh environment that see's on avg a daily temp swing of 40d F and temps as high as 100d F in the summer and so far as low as 15 d F in the winter.....not one problem yet.....and I've grounded the cases two....
Gregg
oliverb
Post by oliverb »
Thanks for the info Gregg. I have seen a few posts about problems with the supplied PSU with the ALIX.1D.
The problem here in the UK is no one seems to sell any of the hardware.
I decided on the ALIX.1D as I have found a supplier in Germany who sells the whole kit with Meteohub preloaded at a very good price. The PSU will not work in the UK but from posts on this forum it seems the PSU need changing anyway.
I am also not sure about customs duty from goods purchased in the US. I bought an item from Canada this year only for it to be intercepted by customs. It ended up costing me tax, extra postage and a handling fee.
I will have to check if buying from an EU country I pay local tax only.
Brett.
Post by skyewright »
oliverb wrote:Thanks for the info Gregg. I have seen a few posts about problems with the supplied PSU with the ALIX.1D.
Maybe you didn't find LinTx?
They are in the UK and both my ALIX-1D's came from there and I'd happily use them again - though I would not get the standard PSU. The PSU's I now use came from Watt-Power, they were a few pounds more expensive that the standard PSU's but much better suited to the job if your power supply is at all unstable.
oliverb
Post by oliverb »
Thanks for the info. Added it to my bookmarks. Did you use a case from their site as well?
Brett.
oliverb wrote:Thanks for the info. Added it to my bookmarks. Did you use a case from their site as well?
Yes, and the CF card.
Since then I've made a slight modification to one of the cases (I used a hacksaw to cut a short slot in the back edge!) to allow access for the lead of a dual port USB that plugs into the 10 pin header on the Motherboard. That takes the total number of USB ports up to 4. I got the dual port USB from Maplin.
oliverb
Post by oliverb »
Did you use this PSU (from another thread) in the end and if so any problems? http://www.watt-power.co.uk/catalogue/w ... ibuty_on=1
Brett.
oliverb wrote:Did you use this PSU (from another thread) in the end and if so any problems? http://www.watt-power.co.uk/catalogue/w ... ibuty_on=1
Yes. Model PSA15W-120.
I have two. Both have behaved well.
N.B. Remember that you will also need the appropriate adaptor to suit the power socket. For my ALIX-1D's that was JACK2.1-2.5.
oliverb
Post by oliverb »
Thanks again skyewright.
oliverb
Post by oliverb »
I am about to order an ALIX-1D from LinITX.com.
They have a couple of industrial 4GB compact flash cards listed
http://linitx.com/viewproduct.php?prodid=11950
and
http://linitx.com/viewproduct.php?prodid=12657
does anyone know if these are SLC type and if it is worth the extra for the 2nd card?
I am going for this case and will build my own PSU with battery backup if possible.
Thanks in advance. Brett. Image
oliverb wrote:I am going for this case and will build my own PSU with battery backup if possible.
A PSU with its own battery backup would be very interesting to hear about.
Please let us know how you get on.
netsigi
Post by netsigi »
This is a really huge case for ALIX...
PSU for Alix can be really small..
http://1wt.eu/articles/alix-ups/
