Update 4.6e (bug-fix release)
What's hot...
mfarmwald
Re:Update 4.6e (bug-fix release)
Post by mfarmwald »
4.6c & 4.6d work more-or-less fine (every second rapid-fire update is dropped). 4.6e doesn't seem to work at all for me (every update seems to be dropped).
Also, the local time doesn't seem to be using DST. (I'm in America/Pacific timezone.) This is a problem with 4.6c, d & e.
I'll look more at this tomorrow. Is there any debug information that would help?
Are you using a NSLU2?
Does "meteohub log" show errors of "bad data records"? Sounds a lot like a bad USB stick.
mfarmwald
Post by mfarmwald »
Yes, I'm using a NLSU2.
No errors in "meteohub log". Don't think there's a problem with USB stick. Works & worked fine with 4.6c & 4.6d.
I'm happy to upload logs or whatever.
mfarmwald
Post by mfarmwald »
I also have a SheevaPlug (currently running 4.6). Should I see if it has the same problem?
