Update 4.6e (bug-fix release)
What's hot...
DEUTSCH:
Dieses Update beseitigt eine Reihe von Stabiltätsproblemen in der Interprozesskommunikation verscheidener Meteohub-Dienste. Es wird sehr empfohlen alle installierten 4.6 Meteohub Versionen auf 4.6e zu updaten.
ENGLISH:
This update fixes stability issues in inter-process communication of various Meteohub services. It is highly recommended to update any Meteohub 4.6 installation to 4.6e
Link:
http://www.meteohub.de/joomla/index.php ... &Itemid=29
black23
Re:Update 4.6e
Post by black23 »
Hi Boris,
On my Sheeva Auto upate don't work. Meteohub everytime said that undate was done but I've still 4.6d (Build 89).
Mike
Re:Update 4.6e
Please try again, should now also work for Sheeva.
cswizard
Re:Update 4.6e
Post by cswizard »
Keeping my fingers crossed but the runaway cpu load seems to have stopped and no WU Rapid Fire stoppages yet. System uptime 4hr 29min.
rainman110
Re:Update 4.6e
Post by rainman110 »
I would be happy to try 4.6e as I was experiencing the rapid fire problem with 4.6c, but the auto update on my NSLU2 is downloading 4.6d.
Re:Update 4.6e
As 4.6e is in experimental status, I just enabled auto update for systems that have 4.6d installed. So it will be two installation steps for you.
cswizard
Re:Update 4.6e
Post by cswizard »
I never noticed before but is the system log daemon supposed to exit a few minutes after the system starts up?
Apr 4 23:00:57 (none) syslog.info syslogd started: BusyBox v1.2.1
Apr 4 23:00:57 (none) user.notice kernel: klogd started: BusyBox v1.2.1 (2007.12.25-11:17+0000)
Apr 4 23:00:57 (none) user.notice kernel: Linux version 2.6.21.7 (slug@otto) (gcc version 4.1.2) #1 PREEMPT Mon Dec 24 23:12:24 UTC 2007
Apr 4 23:00:57 (none) user.warn kernel: CPU: XScale-IXP42x Family [690541f1] revision 1 (ARMv5TE), cr=000039ff
Apr 4 23:00:57 (none) user.warn kernel: Machine: Linksys NSLU2
Apr 4 23:00:57 (none) user.warn kernel: Memory policy: ECC disabled, Data cache writeback
Apr 4 23:00:57 (none) user.debug kernel: On node 0 totalpages: 8192
Apr 4 23:00:57 (none) user.debug kernel: DMA zone: 64 pages used for memmap
Apr 4 23:00:57 (none) user.debug kernel: DMA zone: 0 pages reserved
Apr 4 23:00:57 (none) user.debug kernel: DMA zone: 8128 pages, LIFO batch:0
Apr 4 23:00:57 (none) user.debug kernel: Normal zone: 0 pages used for memmap
Apr 4 23:00:57 (none) user.warn kernel: CPU0: D VIVT undefined 5 cache
Apr 4 23:00:57 (none) user.warn kernel: CPU0: I cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
Apr 4 23:00:57 (none) user.warn kernel: CPU0: D cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
Apr 4 23:00:57 (none) user.warn kernel: Built 1 zonelists. Total pages: 8128
Apr 4 23:00:57 (none) user.notice kernel: Kernel command line: rtc-x1205.probe=0,0x6f console=ttyS0,115200n8 root=/dev/mtdblock4 rootfstype=jffs2 rw init=/linuxrc noirqdebug
Apr 4 23:00:57 (none) user.info kernel: IRQ lockup detection disabled
Apr 4 23:00:57 (none) user.warn kernel: PID hash table entries: 128 (order: 7, 512 bytes)
Apr 4 23:00:57 (none) user.warn kernel: Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Apr 4 23:00:57 (none) user.warn kernel: Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Apr 4 23:00:57 (none) user.info kernel: Memory: 32MB = 32MB total
Apr 4 23:00:57 (none) user.notice kernel: Memory: 30292KB available (1912K code, 153K data, 84K init)
Apr 4 23:00:57 (none) user.debug kernel: Calibrating delay loop... 132.71 BogoMIPS (lpj=663552)
Apr 4 23:00:57 (none) user.warn kernel: Mount-cache hash table entries: 512
Apr 4 23:00:57 (none) user.info kernel: CPU: Testing write buffer coherency: ok
Apr 4 23:00:57 (none) user.info kernel: NET: Registered protocol family 16
Apr 4 23:00:57 (none) user.warn kernel: IXP4xx: Using 16MiB expansion bus window size
Apr 4 23:00:57 (none) user.warn kernel: PCI: IXP4xx is host
Apr 4 23:00:57 (none) user.warn kernel: PCI: IXP4xx Using direct access for memory space
Apr 4 23:00:57 (none) user.info kernel: PCI: bus0: Fast back to back transfers disabled
Apr 4 23:00:57 (none) user.info kernel: dmabounce: registered device 0000:00:01.0 on pci bus
Apr 4 23:00:57 (none) user.info kernel: dmabounce: registered device 0000:00:01.1 on pci bus
Apr 4 23:00:57 (none) user.info kernel: dmabounce: registered device 0000:00:01.2 on pci bus
Apr 4 23:00:57 (none) user.notice kernel: SCSI subsystem initialized
Apr 4 23:00:57 (none) user.info kernel: usbcore: registered new interface driver usbfs
Apr 4 23:00:57 (none) user.info kernel: usbcore: registered new interface driver hub
Apr 4 23:00:57 (none) user.info kernel: usbcore: registered new device driver usb
Apr 4 23:00:57 (none) user.info kernel: Time: OSTS clocksource has been installed.
Apr 4 23:00:57 (none) user.info kernel: NET: Registered protocol family 2
Apr 4 23:00:57 (none) user.warn kernel: IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Apr 4 23:00:57 (none) user.warn kernel: TCP established hash table entries: 1024 (order: 1, 8192 bytes)
Apr 4 23:00:57 (none) user.warn kernel: TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
Apr 4 23:00:57 (none) user.info kernel: TCP: Hash tables configured (established 1024 bind 1024)
Apr 4 23:00:57 (none) user.info kernel: TCP reno registered
Apr 4 23:00:57 (none) user.warn kernel: NetWinder Floating Point Emulator V0.97 (double precision)
Apr 4 23:00:57 (none) user.info kernel: JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
Apr 4 23:00:57 (none) user.info kernel: io scheduler noop registered
Apr 4 23:00:57 (none) user.info kernel: io scheduler deadline registered (default)
Apr 4 23:00:57 (none) user.info kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
Apr 4 23:00:57 (none) user.info kernel: serial8250.0: ttyS0 at MMIO 0xc8000000 (irq = 15) is a XScale
Apr 4 23:00:57 (none) user.info kernel: serial8250.0: ttyS1 at MMIO 0xc8001000 (irq = 13) is a XScale
Apr 4 23:00:57 (none) user.warn kernel: RAMDISK driver initialized: 4 RAM disks of 10240K size 1024 blocksize
Apr 4 23:00:57 (none) user.info kernel: IXP4XX NPE driver Version 0.3.0 initialized
Apr 4 23:00:57 (none) user.info kernel: NFTL driver: nftlcore.c $Revision: 1.98 $, nftlmount.c $Revision: 1.41 $
Apr 4 23:00:57 (none) user.info kernel: IXP4XX-Flash.0: Found 1 x16 devices at 0x0 in 16-bit bank
Apr 4 23:00:57 (none) user.debug kernel: IXP4XX-Flash.0: Found an alias at 0x800000 for the chip at 0x0
Apr 4 23:00:57 (none) user.warn kernel: Intel/Sharp Extended Query Table at 0x0031
Apr 4 23:00:57 (none) user.info kernel: Using buffer write method
Apr 4 23:00:57 (none) user.notice kernel: cfi_cmdset_0001: Erase suspend on write enabled
Apr 4 23:00:57 (none) user.debug kernel: erase region 0: offset=0x0,size=0x20000,blocks=64
Apr 4 23:00:57 (none) user.notice kernel: Searching for RedBoot partition table in IXP4XX-Flash.0 at offset 0x7e0000
Apr 4 23:00:57 (none) user.notice kernel: 6 RedBoot partitions found on MTD device IXP4XX-Flash.0
Apr 4 23:00:57 (none) user.notice kernel: Creating 6 MTD partitions on "IXP4XX-Flash.0":
Apr 4 23:00:57 (none) user.notice kernel: 0x00000000-0x00040000 : "RedBoot"
Apr 4 23:00:57 (none) user.info kernel: nslu2 mac: 00:18:39:a2:23:07
Apr 4 23:00:57 (none) user.notice kernel: 0x00040000-0x00060000 : "SysConf"
Apr 4 23:00:57 (none) user.notice kernel: 0x00060000-0x00080000 : "Loader"
Apr 4 23:00:57 (none) user.notice kernel: 0x00080000-0x00180000 : "Kernel"
Apr 4 23:00:57 (none) user.notice kernel: 0x00180000-0x007e0000 : "Flashdisk"
Apr 4 23:00:57 (none) user.notice kernel: 0x007e0000-0x00800000 : "FIS directory"
Apr 4 23:00:57 (none) user.warn kernel: npe: searching for firmware...
Apr 4 23:00:57 (none) user.info kernel: npe: found at 0x1c010, IXP425/NPE-B func: 00, rev: 2.1, size: 11964, id: 01000201
Apr 4 23:00:57 (none) user.info kernel: Image loaded to NPE-B Func:0, Rel: 2:1, Status: 82c00000
Apr 4 23:00:57 (none) user.info kernel: Initializing USB Mass Storage driver...
Apr 4 23:00:57 (none) user.info kernel: usbcore: registered new interface driver usb-storage
Apr 4 23:00:57 (none) user.info kernel: USB Mass Storage support registered.
Apr 4 23:00:57 (none) user.info kernel: input: ixp4xx beeper as /class/input/input0
Apr 4 23:00:57 (none) user.info kernel: i2c /dev entries driver
Apr 4 23:00:57 (none) user.info kernel: x1205 0-006f: chip found, driver version 1.0.7
Apr 4 23:00:57 (none) user.info kernel: x1205 0-006f: rtc core: registered x1205 as rtc0
Apr 4 23:00:57 (none) user.info kernel: Registered led device: ready
Apr 4 23:00:57 (none) user.info kernel: Registered led device: status
Apr 4 23:00:57 (none) user.info kernel: Registered led device: disk-1
Apr 4 23:00:57 (none) user.info kernel: >Registered led device: disk-2
Apr 4 23:00:57 (none) user.info kernel: TCP cubic registered
Apr 4 23:00:57 (none) user.info kernel: NET: Registered protocol family 17
Apr 4 23:00:57 (none) user.info kernel: XScale DSP coprocessor detected.
Apr 4 23:00:57 (none) user.info kernel: x1205 0-006f: setting the system clock to 2010-04-04 23:00:23 (1270422023)
Apr 4 23:00:57 (none) user.warn kernel: VFS: Mounted root (jffs2 filesystem).
Apr 4 23:00:57 (none) user.info kernel: Freeing init memory: 84K
Apr 4 23:00:57 (none) user.warn kernel: PCI: enabling device 0000:00:01.2 (0140 -> 0142)
Apr 4 23:00:57 (none) user.info kernel: ehci_hcd 0000:00:01.2: EHCI Host Controller
Apr 4 23:00:57 (none) user.info kernel: ehci_hcd 0000:00:01.2: new USB bus registered, assigned bus number 1
Apr 4 23:00:57 (none) user.info kernel: ehci_hcd 0000:00:01.2: irq 26, io mem 0x48002000
Apr 4 23:00:57 (none) user.info kernel: ehci_hcd 0000:00:01.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Apr 4 23:00:57 (none) user.info kernel: usb usb1: configuration #1 chosen from 1 choice
Apr 4 23:00:57 (none) user.info kernel: hub 1-0:1.0: USB hub found
Apr 4 23:00:57 (none) user.info kernel: hub 1-0:1.0: 5 ports detected
Apr 4 23:00:57 (none) user.debug kernel: ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
Apr 4 23:00:57 (none) user.warn kernel: PCI: enabling device 0000:00:01.0 (0140 -> 0142)
Apr 4 23:00:57 (none) user.info kernel: ohci_hcd 0000:00:01.0: OHCI Host Controller
Apr 4 23:00:57 (none) user.info kernel: ohci_hcd 0000:00:01.0: new USB bus registered, assigned bus number 2
Apr 4 23:00:57 (none) user.info kernel: ohci_hcd 0000:00:01.0: irq 28, io mem 0x48000000
Apr 4 23:00:57 (none) user.info kernel: usb usb2: configuration #1 chosen from 1 choice
Apr 4 23:00:57 (none) user.info kernel: hub 2-0:1.0: USB hub found
Apr 4 23:00:57 (none) user.info kernel: hub 2-0:1.0: 3 ports detected
Apr 4 23:00:57 (none) user.warn kernel: PCI: enabling device 0000:00:01.1 (0140 -> 0142)
Apr 4 23:00:57 (none) user.info kernel: ohci_hcd 0000:00:01.1: OHCI Host Controller
Apr 4 23:00:57 (none) user.info kernel: ohci_hcd 0000:00:01.1: new USB bus registered, assigned bus number 3
Apr 4 23:00:57 (none) user.info kernel: ohci_hcd 0000:00:01.1: irq 27, io mem 0x48001000
Apr 4 23:00:57 (none) user.info kernel: usb usb3: configuration #1 chosen from 1 choice
Apr 4 23:00:57 (none) user.info kernel: hub 3-0:1.0: USB hub found
Apr 4 23:00:57 (none) user.info kernel: hub 3-0:1.0: 2 ports detected
Apr 4 23:00:57 (none) user.info kernel: usb 1-2: new high speed USB device using ehci_hcd and address 3
Apr 4 23:00:57 (none) user.info kernel: usb 1-2: configuration #1 chosen from 1 choice
Apr 4 23:00:57 (none) user.info kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Apr 4 23:00:57 (none) user.debug kernel: usb-storage: device found at 3
Apr 4 23:00:57 (none) user.debug kernel: usb-storage: waiting for device to settle before scanning
Apr 4 23:00:57 (none) user.info kernel: usb 2-1: new low speed USB device using ohci_hcd and address 2
Apr 4 23:00:57 (none) user.info kernel: usb 2-1: configuration #1 chosen from 1 choice
Apr 4 23:00:57 (none) user.notice kernel: scsi 0:0:0:0: Direct-Access ZyRUS mini Swing Plus 1100 PQ: 0 ANSI: 0 CCS
Apr 4 23:00:57 (none) user.notice kernel: SCSI device sda: 3915776 512-byte hdwr sectors (2005 MB)
Apr 4 23:00:57 (none) user.notice kernel: sda: Write Protect is off
Apr 4 23:00:57 (none) user.debug kernel: sda: Mode Sense: 43 00 00 00
Apr 4 23:00:57 (none) user.err kernel: sda: assuming drive cache: write through
Apr 4 23:00:57 (none) user.info kernel: sda: sda1 sda2 sda3
Apr 4 23:00:57 (none) user.notice kernel: sd 0:0:0:0: Attached scsi removable disk sda
Apr 4 23:00:57 (none) user.debug kernel: usb-storage: device scan complete
Apr 4 23:00:57 (none) user.info kernel: kjournald starting. Commit interval 5 seconds
Apr 4 23:00:57 (none) user.warn kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Apr 4 23:00:57 (none) user.info kernel: EXT3 FS on sda1, internal journal
Apr 4 23:00:57 (none) user.info kernel: EXT3-fs: mounted filesystem with ordered data mode.
Apr 4 23:00:57 (none) user.info kernel: IXP4XX Q Manager 0.2.1 initialized.
Apr 4 23:00:57 (none) user.info kernel: ixp4xx_mac driver 0.3.1: eth0 on NPE-B with PHY[1] initialized
Apr 4 23:00:57 (none) user.info kernel: usbcore: registered new interface driver hiddev
Apr 4 23:00:57 (none) user.info kernel: hiddev96: USB HID v1.10 Device [Universal Bridge] on usb-0000:00:01.0-1
Apr 4 23:00:57 (none) user.info kernel: usbcore: registered new interface driver usbhid
Apr 4 23:00:57 (none) user.info kernel: drivers/usb/input/hid-core.c: v2.6:USB HID core driver
Apr 4 23:00:57 (none) user.info kernel: EXT3 FS on sda3, internal journal
Apr 4 23:00:57 (none) user.info kernel: Adding 131064k swap on /dev/sda2. Priority:-1 extents:1 across:131064k
Apr 4 23:00:59 (none) user.info kernel: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
Apr 4 23:00:59 (none) user.debug kernel: Link of eth0 is full-duplex
Apr 4 23:01:02 (none) user.warn kernel: IXP4xx Watchdog Timer: heartbeat 60 sec
Apr 4 23:01:02 (none) user.info kernel: usbcore: registered new interface driver usbserial
Apr 4 23:01:02 (none) user.info kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
Apr 4 23:01:02 (none) user.info kernel: usbcore: registered new interface driver usbserial_generic
Apr 4 23:01:02 (none) user.info kernel: drivers/usb/serial/usb-serial.c: USB Serial Driver core
Apr 4 23:01:02 (none) user.info kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for pl2303
Apr 4 23:01:02 (none) user.info kernel: usbcore: registered new interface driver pl2303
Apr 4 23:01:02 (none) user.info kernel: drivers/usb/serial/pl2303.c: Prolific PL2303 USB to serial adaptor driver
Apr 4 23:01:02 (none) user.info kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for cp2101
Apr 4 23:01:02 (none) user.info kernel: usbcore: registered new interface driver cp2101
Apr 4 23:01:02 (none) user.info kernel: drivers/usb/serial/cp2101.c: Silicon Labs CP2101/CP2102 RS232 serial adaptor driver v0.07
Apr 4 23:01:02 (none) user.info kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for FTDI USB Serial Device
Apr 4 23:01:02 (none) user.info kernel: usbcore: registered new interface driver ftdi_sio
Apr 4 23:01:02 (none) user.info kernel: drivers/usb/serial/ftdi_sio.c: v1.4.3:USB FTDI Serial Converters Driver
Apr 4 23:01:03 (none) user.notice root: restart without recomputation of data (scheduled reboot, manual reboot)
Apr 4 23:01:03 (none) daemon.info init: Entering runlevel: 3
Apr 4 23:01:04 (none) auth.info sshd[1030]: Server listening on 0.0.0.0 port 22.
Apr 4 23:01:08 (none) user.debug kernel: usb 2-1: usbfs: USBDEVFS_CONTROL failed cmd hidlog3 rqt 129 rq 6 len 34 ret -75
Apr 4 23:01:09 (none) daemon.crit thttpd[1111]: socket :: - Address family not supported by protocol
Apr 4 23:01:09 (none) daemon.notice thttpd[1111]: thttpd/2.25b 29dec2003 starting on port 80
Apr 4 23:01:09 (none) daemon.warn thttpd[1111]: started as root without requesting chroot(), warning only
Apr 4 23:01:09 (none) daemon.crit thttpdbackup[1117]: socket :: - Address family not supported by protocol
Apr 4 23:01:09 (none) daemon.notice thttpdbackup[1117]: thttpd/2.25b 29dec2003 starting on port 7777
Apr 4 23:01:09 (none) daemon.warn thttpdbackup[1117]: started as root without requesting chroot(), warning only
Apr 4 23:01:09 (none) daemon.notice ntpd[1129]: ntpd 4.2.2p3@1.1577 Sat Feb 9 23:00:06 UTC 2008 (1)
Apr 4 23:01:09 (none) daemon.info ntpd[1130]: precision = 12.000 usec
Apr 4 23:01:10 (none) daemon.info thttpd[1111]: spawned CGI process 1134 for file 'meteolog.cgi'
Apr 4 23:01:10 (none) daemon.debug ntpd[1130]: ntp_io: estimated max descriptors: 1024, initial socket boundary: 16
Apr 4 23:01:10 (none) daemon.info ntpd[1130]: Listening on interface wildcard, 0.0.0.0#123 Disabled
Apr 4 23:01:10 (none) daemon.info ntpd[1130]: Listening on interface lo, 127.0.0.1#123 Enabled
Apr 4 23:01:10 (none) daemon.info ntpd[1130]: Listening on interface eth0, 192.168.0.251#123 Enabled
Apr 4 23:01:10 (none) daemon.info ntpd[1130]: Listening on interface eth0:0, 192.168.1.77#123 Enabled
Apr 4 23:01:10 (none) daemon.info ntpd[1130]: kernel time sync status 0040
Apr 4 23:01:11 (none) cron.info /usr/sbin/cron[1153]: (CRON) STARTUP (fork ok)
Apr 4 23:01:11 (none) cron.info /usr/sbin/cron[1153]: (root.new) ORPHAN (no passwd entry)
Apr 4 23:01:11 (none) cron.info /usr/sbin/cron[1153]: (root.boot) ORPHAN (no passwd entry)
Apr 4 23:01:14 (none) daemon.info thttpd[1111]: spawned CGI process 1196 for file 'meteolog.cgi'
Apr 4 23:01:18 (none) daemon.info thttpd[1111]: spawned CGI process 1198 for file 'meteolog.cgi'
Apr 4 23:01:22 (none) daemon.info thttpd[1111]: spawned CGI process 1200 for file 'meteolog.cgi'
Apr 4 23:01:26 (none) daemon.info thttpd[1111]: spawned CGI process 1202 for file 'meteolog.cgi'
Apr 4 23:01:30 (none) daemon.info thttpd[1111]: spawned CGI process 1204 for file 'meteolog.cgi'
Apr 4 23:01:34 (none) daemon.info thttpd[1111]: spawned CGI process 1206 for file 'meteolog.cgi'
Apr 4 23:01:38 (none) daemon.info thttpd[1111]: spawned CGI process 1208 for file 'meteolog.cgi'
Apr 4 23:01:43 (none) daemon.info thttpd[1111]: spawned CGI process 1210 for file 'meteolog.cgi'
Apr 4 23:01:47 (none) daemon.info thttpd[1111]: spawned CGI process 1212 for file 'meteolog.cgi'
Apr 4 23:01:50 (none) daemon.info thttpd[1111]: spawned CGI process 1214 for file 'meteolog.cgi'
Apr 4 23:01:55 (none) daemon.info thttpd[1111]: spawned CGI process 1216 for file 'meteolog.cgi'
Apr 4 23:01:59 (none) daemon.info thttpd[1111]: spawned CGI process 1218 for file 'meteolog.cgi'
Apr 4 23:02:00 (none) cron.info /USR/SBIN/CRON[1221]: (root) CMD (sleep 8; rm -f /var/run/meteohub/uploads//*)
Apr 4 23:02:00 (none) cron.info /USR/SBIN/CRON[1227]: (root) CMD (/bin/pidof histeval0 || /usr/bin/nice /home/meteohub/histeval0)
Apr 4 23:02:00 (none) cron.info /USR/SBIN/CRON[1225]: (root) CMD (/bin/cat /proc/uptime >/var/run/meteohub/alive)
Apr 4 23:02:00 (none) cron.info /USR/SBIN/CRON[1223]: (root) CMD (/usr/bin/nice /home/meteohub/wmr928eval -c min10 -t -3600 -w /data/weather/ -s /home/meteohub/wmr928eval.conf)
Apr 4 23:02:03 (none) daemon.info thttpd[1111]: spawned CGI process 1235 for file 'meteolog.cgi'
Apr 4 23:02:07 (none) daemon.info thttpd[1111]: spawned CGI process 1245 for file 'meteolog.cgi'
Apr 4 23:02:11 (none) daemon.info thttpd[1111]: spawned CGI process 1251 for file 'meteolog.cgi'
Apr 4 23:02:14 (none) user.debug kernel: usb 2-1: usbfs: USBDEVFS_CONTROL failed cmd hidlog3 rqt 33 rq 9 len 8 ret -110
Apr 4 23:02:15 (none) daemon.info thttpd[1111]: spawned CGI process 1256 for file 'meteolog.cgi'
Apr 4 23:02:19 (none) daemon.info thttpd[1111]: spawned CGI process 1262 for file 'meteolog.cgi'
Apr 4 23:02:23 (none) daemon.info thttpd[1111]: spawned CGI process 1266 for file 'meteolog.cgi'
Apr 4 23:02:27 (none) daemon.info thttpd[1111]: spawned CGI process 1272 for file 'meteolog.cgi'
Apr 4 23:02:31 (none) daemon.info thttpd[1111]: spawned CGI process 1276 for file 'meteolog.cgi'
Apr 4 23:02:35 (none) daemon.info thttpd[1111]: spawned CGI process 1280 for file 'meteolog.cgi'
Apr 4 23:02:40 (none) daemon.info thttpd[1111]: spawned CGI process 1284 for file 'meteolog.cgi'
Apr 4 23:02:44 (none) daemon.info thttpd[1111]: spawned CGI process 1288 for file 'meteolog.cgi'
Apr 4 23:02:48 (none) daemon.info thttpd[1111]: spawned CGI process 1293 for file 'meteolog.cgi'
Apr 4 23:02:51 (none) daemon.info thttpd[1111]: spawned CGI process 1298 for file 'meteolog.cgi'
Apr 4 23:02:56 (none) daemon.info thttpd[1111]: spawned CGI process 1302 for file 'meteolog.cgi'
Apr 4 23:03:00 (none) daemon.info thttpd[1111]: spawned CGI process 1306 for file 'meteolog.cgi'
Apr 4 23:03:00 (none) cron.info /USR/SBIN/CRON[1309]: (root) CMD (sleep 8; rm -f /var/run/meteohub/uploads//*)
Apr 4 23:03:00 (none) cron.info /USR/SBIN/CRON[1315]: (root) CMD (/bin/pidof wswinimport || /usr/bin/nice /home/meteohub/wswinimport 2>>/data/log/messages)
Apr 4 23:03:00 (none) cron.info /USR/SBIN/CRON[1311]: (root) CMD (/usr/bin/nice /home/meteohub/wmr928eval -c hour1 -t -7200 -w /data/weather/ -s /home/meteohub/wmr928eval.conf)
Apr 4 23:03:00 (none) cron.info /USR/SBIN/CRON[1319]: (root) CMD (/bin/pidof histeval0 || /usr/bin/nice /home/meteohub/histeval0)
Apr 4 23:03:00 (none) cron.info /USR/SBIN/CRON[1317]: (root) CMD (/bin/cat /proc/uptime >/var/run/meteohub/alive)
Apr 4 23:03:00 (none) cron.info /USR/SBIN/CRON[1313]: (root) CMD (/usr/bin/nice /home/meteohub/wmr928eval -c min30 -t -7200 -w /data/weather/ -s /home/meteohub/wmr928eval.conf)
Apr 4 23:03:04 (none) daemon.info thttpd[1111]: spawned CGI process 1333 for file 'meteolog.cgi'
Apr 4 23:03:08 (none) daemon.info thttpd[1111]: spawned CGI process 1337 for file 'meteolog.cgi'
Apr 4 23:03:12 (none) daemon.info thttpd[1111]: spawned CGI process 1342 for file 'meteolog.cgi'
Apr 4 23:03:16 (none) daemon.info thttpd[1111]: spawned CGI process 1346 for file 'meteolog.cgi'
Apr 4 23:03:20 (none) daemon.info thttpd[1111]: spawned CGI process 1350 for file 'meteolog.cgi'
Apr 4 23:03:24 (none) daemon.info thttpd[1111]: spawned CGI process 1354 for file 'meteolog.cgi'
Apr 4 23:03:28 (none) daemon.info thttpd[1111]: spawned CGI process 1358 for file 'meteolog.cgi'
Apr 4 23:03:32 (none) daemon.info thttpd[1111]: spawned CGI process 1362 for file 'meteolog.cgi'
Apr 4 23:03:36 (none) daemon.info thttpd[1111]: spawned CGI process 1366 for file 'meteolog.cgi'
Apr 4 23:03:40 (none) daemon.info thttpd[1111]: spawned CGI process 1370 for file 'meteolog.cgi'
Apr 4 23:03:44 (none) daemon.info thttpd[1111]: spawned CGI process 1374 for file 'meteolog.cgi'
Apr 4 23:03:49 (none) daemon.info thttpd[1111]: spawned CGI process 1378 for file 'meteolog.cgi'
Apr 4 23:03:53 (none) daemon.info thttpd[1111]: spawned CGI process 1383 for file 'meteolog.cgi'
Apr 4 23:03:57 (none) daemon.info thttpd[1111]: spawned CGI process 1388 for file 'meteolog.cgi'
Apr 4 23:04:00 (none) cron.info /USR/SBIN/CRON[1393]: (root) CMD (sleep 8; rm -f /var/run/meteohub/uploads//*)
Apr 4 23:04:00 (none) cron.info /USR/SBIN/CRON[1397]: (root) CMD (/bin/pidof histeval0 || /usr/bin/nice /home/meteohub/histeval0)
Apr 4 23:04:01 (none) cron.info /USR/SBIN/CRON[1395]: (root) CMD (/bin/cat /proc/uptime >/var/run/meteohub/alive)
Apr 4 23:04:01 (none) daemon.info thttpd[1111]: spawned CGI process 1404 for file 'meteolog.cgi'
Apr 4 23:04:05 (none) daemon.info thttpd[1111]: spawned CGI process 1408 for file 'meteolog.cgi'
Apr 4 23:04:09 (none) daemon.info thttpd[1111]: spawned CGI process 1413 for file 'meteolog.cgi'
Apr 4 23:04:13 (none) daemon.info thttpd[1111]: spawned CGI process 1417 for file 'meteolog.cgi'
Apr 4 23:04:17 (none) daemon.info thttpd[1111]: spawned CGI process 1421 for file 'meteolog.cgi'
Apr 4 23:04:21 (none) daemon.info thttpd[1111]: spawned CGI process 1425 for file 'meteolog.cgi'
Apr 4 23:04:25 (none) daemon.info thttpd[1111]: spawned CGI process 1429 for file 'meteolog.cgi'
Apr 4 23:04:29 (none) daemon.info thttpd[1111]: spawned CGI process 1433 for file 'meteolog.cgi'
Apr 4 23:04:34 (none) daemon.info thttpd[1111]: spawned CGI process 1437 for file 'meteolog.cgi'
Apr 4 23:04:38 (none) daemon.info thttpd[1111]: spawned CGI process 1441 for file 'meteolog.cgi'
Apr 4 23:04:42 (none) daemon.info thttpd[1111]: spawned CGI process 1445 for file 'meteolog.cgi'
Apr 4 23:04:46 (none) daemon.info thttpd[1111]: spawned CGI process 1449 for file 'meteolog.cgi'
Apr 4 23:04:57 (none) daemon.info thttpd[1111]: spawned CGI process 1457 for file 'meteolog.cgi'
Apr 4 23:05:00 (none) cron.info /USR/SBIN/CRON[1462]: (root) CMD (sleep 8; rm -f /var/run/meteohub/uploads//*)
Apr 4 23:05:01 (none) cron.info /USR/SBIN/CRON[1465]: (root) CMD (/home/meteohub/wmr928fullevalwrapper >/dev/null 2>>/data/log/messages)
Apr 4 23:05:01 (none) cron.info /USR/SBIN/CRON[1470]: (root) CMD (/bin/pidof histeval0 || /usr/bin/nice /home/meteohub/histeval0)
Apr 4 23:05:01 (none) cron.info /USR/SBIN/CRON[1467]: (root) CMD (/bin/pidof histeval1 || /usr/bin/nice /home/meteohub/histeval1)
Apr 4 23:05:01 (none) cron.info /USR/SBIN/CRON[1472]: (root) CMD (/bin/cat /proc/uptime >/var/run/meteohub/alive)
Apr 4 23:05:01 (none) cron.info /USR/SBIN/CRON[1471]: (root) CMD (sleep 120; /home/meteohub/meteonet)
Apr 4 23:05:01 (none) daemon.info thttpd[1111]: spawned CGI process 1481 for file 'meteolog.cgi'
Apr 4 23:05:06 (none) daemon.info thttpd[1111]: spawned CGI process 1496 for file 'meteolog.cgi'
Apr 4 23:05:10 (none) daemon.info thttpd[1111]: spawned CGI process 1503 for file 'meteolog.cgi'
Apr 4 23:05:14 (none) daemon.info thttpd[1111]: spawned CGI process 1510 for file 'meteolog.cgi'
Apr 4 23:05:18 (none) daemon.info thttpd[1111]: spawned CGI process 1514 for file 'meteolog.cgi'
Apr 4 23:05:22 (none) daemon.info thttpd[1111]: spawned CGI process 1519 for file 'meteolog.cgi'
Apr 4 23:05:26 (none) daemon.info thttpd[1111]: spawned CGI process 1523 for file 'meteolog.cgi'
Apr 4 23:05:31 (none) daemon.info thttpd[1111]: spawned CGI process 1527 for file 'meteolog.cgi'
Apr 4 23:05:35 (none) daemon.info thttpd[1111]: spawned CGI process 1531 for file 'meteolog.cgi'
Apr 4 23:05:39 (none) daemon.info thttpd[1111]: spawned CGI process 1535 for file 'meteolog.cgi'
Apr 4 23:05:43 (none) daemon.info thttpd[1111]: spawned CGI process 1539 for file 'meteolog.cgi'
Apr 4 23:05:47 (none) daemon.info thttpd[1111]: spawned CGI process 1543 for file 'meteolog.cgi'
Apr 4 23:05:51 (none) daemon.info thttpd[1111]: spawned CGI process 1547 for file 'meteolog.cgi'
Apr 4 23:05:55 (none) daemon.info thttpd[1111]: spawned CGI process 1551 for file 'meteolog.cgi'
Apr 4 23:05:59 (none) daemon.info thttpd[1111]: spawned CGI process 1557 for file 'meteolog.cgi'
Apr 4 23:06:00 (none) user.debug kernel: usb 2-1: usbfs: USBDEVFS_CONTROL failed cmd hidlog3 rqt 33 rq 9 len 8 ret -110
Apr 4 23:06:01 (none) cron.info /USR/SBIN/CRON[1562]: (root) CMD (sleep 8; rm -f /var/run/meteohub/uploads//*)
Apr 4 23:06:01 (none) cron.info /USR/SBIN/CRON[1564]: (root) CMD (sleep 0; /srv/www/meteograph.cgi text all>/var/run/meteohub/all-sensors0.txt; /srv/www/cgi-bin/stamp.cgi cp "/var/run/meteohub/all-sensors0.txt" "/var/run/meteohub/perm/all-sensors"; /srv/www/cgi-bin/stamp.cgi cp "/var/run/meteohub/all-sensors0.txt" "/data/myweb/uploads/all-sensors"; /srv/www/cgi-bin/stamp.cgi mv "/var/run/meteohub/all-sensors0.txt" "/var/run/meteohub/uploads/all-sensors")
Apr 4 23:06:01 (none) cron.info /USR/SBIN/CRON[1568]: (root) CMD (/bin/cat /proc/uptime >/var/run/meteohub/alive)
Apr 4 23:06:01 (none) cron.info /USR/SBIN/CRON[1570]: (root) CMD (/bin/pidof histeval0 || /usr/bin/nice /home/meteohub/histeval0)
Apr 4 23:06:01 (none) cron.info /USR/SBIN/CRON[1566]: (root) CMD (/bin/pidof wswinimport || /usr/bin/nice /home/meteohub/wswinimport 2>>/data/log/messages)
Apr 4 23:06:04 (none) daemon.info thttpd[1111]: spawned CGI process 1584 for file 'meteolog.cgi'
Apr 4 23:06:06 (none) syslog.info System log daemon exiting.
Re:Update 4.6e
that is normal behavior. syslog is very verbose and does produce a lot of wear on the flash card. Therefore, Meteohub does halt this after some minutes.
Vetinari
Re:Update 4.6e
Post by Vetinari »
My sheeva has since 4.6d no high cpu load anymore. But I can´t say anything about the rapidfire issue.
gm4jjj
Re:Update 4.6e
Post by gm4jjj »
No problems here with Rapidfire updates since 4.6e.
cswizard
Re:Update 4.6e
Post by cswizard »
That makes sense...I'd just never noticed it before.
cswizard
Re:Update 4.6e
Post by cswizard »
Rapid Fire hasn't stopped yet. System Load seems acceptable. The system hasn't gone unresponsive yet. I do note that occasionally when the System Info page refreshes the page is blank. Manual refresh makes it come back ok.
rainman110
Re:Update 4.6e
Running 4.6e on my NSLU2 for over 24 hours now, so far the 4.6c WU rapid fire issue has not reappeared.
gibsonmb
Re:Update 4.6e
Post by gibsonmb »
Also running 4.6e, all seems fine so far, only running 4.6e for about 5 hoours so far..... Mike
Re:Update 4.6e (bug-fix release)
Judging from your feedback 4.6e finally did the trick.
It is an official release now, available for manual download and/or auto update.
