Update 4.6s
What's hot...
Re: Update 4.6s
there is a new experimental version that should have this working again.
rabit
Re: Update 4.6s
Post by rabit »
Yes the new 4.6s experimental is working. No problems so far.
Davis VP2 > Weather-Envoy > Weatherlink-IP > SheevaPlug > Meteohub >
rongic
Re: Update 4.6s
Post by rongic »
Thanks Boris, it's working now ! :-)
rongic
Re: Update 4.6s
Post by rongic »
Maybe I have discovered another bug in 4.6s-experimental version...
There are no last15m, last60m, seqmin1 values or they are empty.
hour1_t7_tempmax_f 38.8
hour1_t7_temp_trend -1
last15m_utcdate 20101120152549
last15m_localdate 20101120162549
last24h_utcdate 20101120153549
last24h_localdate 20101120163549
last24h_wind0_maxspeeddir_deg 112.5
last24h_wind0_maxspeeddir_de OSO
last24h_wind0_maxspeeddir_en ESE
last24h_wind0_maindir_deg 202.5
etc..
There is saved meteograph.cgi?text=all -> http://193.179.144.7/text_all_46s-experimental.txt
Re: Update 4.6s
wait until recomputation has run through...
rongic
Re: Update 4.6s
Post by rongic »
admin wrote:wait until recomputation has run through...
Recomputation has finished 40 minutes ago.
wmr928fulleval(20.11.2010 15:35:01): recomputation of weather data started.
wmr928fulleval(20.11.2010 16:04:29): recomputation of weather data finished: 3950669 records processed in 1764 seconds (2239 records per second)
I try reboot system and will see what happen :-)
rongic
Re: Update 4.6s
Post by rongic »
So, reboot and new data recomputation has finished...
wmr928fulleval(20.11.2010 17:00:01): recomputation of weather data started.
wmr928fulleval(20.11.2010 17:29:42): recomputation of weather data finished: 3952753 records processed in 1778 seconds (2223 records per second)
But still same result, no last15m, last60m, seqmin1 values...
There is new version of meteohub.cgi?text=all ->http://193.179.144.7/meteohub/text_all_ ... ntal_2.txt
And there is my custom XML file -> http://193.179.144.7/meteohub/meteohub.xml
In 4.6s it was ok :)
Re: Update 4.6s
are you sure there is logged raw data for last 15 minutes?
HeinrichH
Re: Update 4.6s
Post by HeinrichH »
@ rongic
Which plug in are you using to connect the 1 wire equipment?
rongic
Re: Update 4.6s
Post by rongic »
admin wrote:are you sure there is logged raw data for last 15 minutes?
Oh... You bring me new idea...
System Uptime is now 1 hours, 55 minutes.
But after update, there is no data in graphs - no Vantage or 1-wire data, but If I looking good, i can see them in Inspect data - please see screens below.
Graphs : http://193.179.144.7/meteohub/graphs/
Meteohub screens: http://193.179.144.7/meteohub/screens/
Newest version of meteohub.cgi?text=all and XML are here:
http://193.179.144.7/meteohub/text_all_ ... ntal_3.txt
http://193.179.144.7/meteohub/meteohub2.xml
rongic
Re: Update 4.6s
Post by rongic »
HeinrichH wrote:@ rongic
I am using own simple Perl script which is reading TXT file which is created by Digitemp software. If you are interested, I can send it to you.
HeinrichH
Re: Update 4.6s
Post by HeinrichH »
rongic wrote: I am using own simple Perl script which is reading TXT file which is created by Digitemp software. If you are interested, I can send it to you.
Please send me the script, if possible also instructions how to implement a script, I really don't know how to install or configure a plug-in in the Meteohub system.
rabit
Re: Update 4.6s
Post by rabit »
I have no trends with the actual experimantal 4.6s. ? You still have my actual login data.
http://mannheim-wetter.info/grafik/index24h.shtml.
HeinrichH
Re: Update 4.6s
Post by HeinrichH »
rabit wrote:I have no trends with the actual experimantal 4.6s.
That happens also in my system, the data is available but the graphics seems not to be updated. To be sure I downgraded again to 4.6q, don't forget, it's a experimental update :D
d_l
Re: Update 4.6s
Post by d_l »
I updated my NSLU2 to 4.6s-Experimental and now it is collecting data from the SheevaPlug properly. I left the SheevaPlug at 4.6r. The NSLU2 only puts out a load graph which is working properly and clientraw files.
