Update 4.6u
What's hot...
dls903
Re: Update 4.6u
Post by dls903 »
I have the same problem with the upload to awekas.
The upload to the wetterarchiv don't work.
Dec 15 15:32:02 meteohub kernel: meteonet[6842]: segfault at 00000000 eip b7e2d930 esp bfc2ac44 error 4
Dec 15 16:02:01 meteohub kernel: meteonet[8711]: segfault at 00000000 eip b7e7d930 esp bfe0c384 error 4
Dec 15 16:32:02 meteohub kernel: meteonet[10764]: segfault at 00000000 eip b7e5a930 esp bfc32324 error 4
martin150
Re: Update 4.6u
Post by martin150 »
martin150 wrote:Hi !
I´ve a problem with upload on AWEKAS. After update i´ve been blocked because i send wrong Air Pressure (to low). In the moment my station shows 1015 and awekas receive 1013,2 the last hours.
Also have the same meteonet error 4 like some posts before!
meteonet[2874]: segfault at 00000000 eip b7dbf930 esp bf9eb764 error 4
mfg
Martin
After few errors in systemlog and no data on Awekas, i did downgrade to 4.6r. Dataupload seems to work, but airpressure is to low. My station shows 1014, awekas show 1012 ?!
http://www.awekas.at/de/instrument.php?id=5612 Awekas
http://www.hildner.at/meteo My station
mfG
Martin
Re: Update 4.6u
should be fixed by now.
dls903
Re: Update 4.6u
Post by dls903 »
Awekas and wetterarchiv get now data. thanks
martin150
Re: Update 4.6u
Post by martin150 »
admin wrote:should be fixed by now.
Tnx for service. Awekas receive Data again, and no error on meteohub
BUT, already my problem with airpressure on awekas.
Awekas is the only system that shows airpressure to low (2hpa). In the moment on all "Wetternetzwerke" which receive Data show the correct 1012, but only awekas show 1010 ??
Any help about this ?
mfG
Martin
Re: Update 4.6u
May be there is some confusion abput station pressure and sealevel pressure.
1) what ist your station's altitude?
2) What does "http://ip-of-your-meteohub/meteograph.cgi?text=all" report for pressure and sealevel pressure on your baro sensor (I guess it will be thb0)?
HWTest
Re: Update 4.6u
Post by HWTest »
And what about my problem?
I've re-downloaded and reinstalled 4.6u but it is still build 331.
Now I'm waiting for the recomputation to finish.
Re: Update 4.6u
@HWtest: Meteohub always uses primary outdoor sensor for wind chill computation. Normally this is assigned to th0. So the behavior you describe is what I would expect. I don't think that has changed during the last versions.
HWTest
Re: Update 4.6u
Post by HWTest »
If I'm getting it right, then redefining sensors on the sensor page has no effect on this?
So the Wind Chill calculation setting to "compute from wind a temperature (th0) readings" is misleading because in fact it doesn't use th0, when it was redefined from default?
HWTest
Re: Update 4.6u
Post by HWTest »
I have a hunch, that it worked in 4.6h - is it safe to downgrade to try it out?
Re: Update 4.6u
you will probably loose your settings.
martin150
Re: Update 4.6u
Post by martin150 »
admin wrote:May be there is some confusion abput station pressure and sealevel pressure.
Hi!
Tnx for answer !
1. 880 Meter
2.
actual_thb0_temp_c 22.3
actual_thb0_temp_f 72.1
actual_thb0_hum_rel 30
actual_thb0_hum_abs 5.9
actual_thb0_dew_c 3.9
actual_thb0_dew_f 39.0
actual_thb0_heatindex_c 22.3
actual_thb0_heatindex_f 72.1
actual_thb0_humidex_c 21.2
actual_thb0_humidex_f 70.2
actual_thb0_cloudheight_m 2300
actual_thb0_cloudheight_ft 7360
actual_thb0_press_hpa 902.5
actual_thb0_press_psi 13.09
actual_thb0_press_mmhg 676.8
actual_thb0_press_inhg 26.65
actual_thb0_sealevel_hpa 1006.0
actual_thb0_sealevel_psi 14.59
actual_thb0_sealevel_mmhg 754.5
actual_thb0_sealevel_inhg 29.71
actual_thb0_fc 0
actual_thb0_fc_wdlive 20
On "Normaldruck berechen" i have "Aus Wetterstationshöhe berechnen" selected
Awekas show in same time 1004 ?!
All other networks show correct (Wetterpage24, Wetterpool,...)
mfg
Martin
HWTest
Re: Update 4.6u
Post by HWTest »
admin wrote:@HWtest: Meteohub always uses primary outdoor sensor for wind chill computation. Normally this is assigned to th0. So the behavior you describe is what I would expect. I don't think that has changed during the last versions.
You were right, sadly ...
