Error messages - Can not set local time
Re: Error messages - Can not set local time
please do again, as the tunnel gets closed each night, when my dsl connection does a reset.
Wessel
Post by Wessel »
I did again.
I could login (somehow) via ssh.It prompts as follows...
login as: root
root@mars's password:
-bash: /usr/bin/id: Input/output error
-bash: [: : integer expression expected
-bash: /root/.profile: Input/output error
That means login via ssh does already fail. no operation from that. This all looks like a seriously damaged SD card.
You will have to do a new SD card setup, with a freah SD card.
Wessel
Post by Wessel »
It's a pitty, then I will buy a new license for my another MetoSheeva. Thanks.
activation codes can be transferred. you don't need a new license when changing the media.
longtian006
Post by longtian006 »
SD card change does also change system ID. Therefore you need to transfer activation code with the link given above. Make sure to pick the right scenario.
__________________________________________________________
PIPO Android Tablet PC PIPO U1Pro Android Tablet pc PIPO M8 Android 4.1 Tablet PC
everbeen
Post by everbeen »
thanks, This help me a lot. and I won't buy sd card for it's low price.
