No sensors assigned on RMS300
stein42
Re: No sensors assigned on RMS300
Post by stein42 »
That's strange
In Maintenance tab it says that no update is available when I click on Check for update
And I do not understand how I can do that manually
stein42
Post by stein42 »
stein42 wrote:That's strange
Is it normal ?
wfpost
Post by wfpost »
the manual describes in detail the three methods available to update the firmware.
simply follow pages 38/39
stein42
Post by stein42 »
I already read notice.
With "Check for updates" button in Maintenance tab, I have the following message : "No update available"
I don't understand where I have to browse for the "Web" method
And I have a problem with third method ("file" one). I am trying to connect via putty but I forgot my password...
:oops:
wfpost
Post by wfpost »
download the 4.7f update from meteohubs website.
http://wiki.meteohub.de/Updates
copy it to meteohubs network folder
\\ip-of-your-meteohub\transfer
Open meteohub webinterface and enter this on the Maintainance site (screenshot below)
/data/transfer/update-v4.7f.upd
Click install
Be aware, that an update with NSLU2 and USB Sticks is always problematic, as it tends to crash the system, if the USB-Sticks already has too many bad sectors.
You´ll find dozens of entries here with the forum about that issue.
So, a backup is a must before updating an NSLU2, I guess.
stein42
Post by stein42 »
Thanks update is done now (I am really a newbie)
Unfortunately it doesn't fix the problem and I always have this message in sensor page :
error connect socket 127.0.0.1:5555 :Connection refused
Warning: Data logging has been halted.
:cry:
please browse to "http://ip-of-your-meteohub/cgi-bin/help.cgi", this will allow me to login.
stein42
Post by stein42 »
That's done !!
stein42
Post by stein42 »
Eureka the message
just dissapeared !!
stein42
Post by stein42 »
The message has dissapeared but it can't find any sensor...
does work now. I did not change anything, did you?
stein42
Post by stein42 »
Previously to my last checking one sensor was near the weather station.
I moved it tonight and now it works I saw my 3 sensors.
That's very strange...
