I try the file whit old Management of Weather Graphs configuration....
Thanks for you patience and sorry for my bad english!!!
Update 4.7j
Re: Update 4.7j
Coming back to that, I have no uploaded all my data to meteoplug and from that, I can tell.admin wrote:Could be a result of how Meteohub computes averages. Meteohub assumes that data pops up at more or less constant and regular intervals. It sums up all values and divides it by the number of samples. When you have more samples in winter month than in summer month, because you changed your weather station type i.e., than this assumption is false and values might show a drift in the direction to the higher sampling rate.
Meteoplug does compute that in another way. Does Meteoplug show the same effects on your data?
meteoplug and the exported wswin data show the exact same monthly temp averages.
So it seems, there is something wrong with the seqmonth1_th0_temp_c values, because these values are too high.
