Sennsors error
N5XL
Re: Sennsors error
Post by N5XL »
It sounds like the hardware is working, based on the description of the LED lights you mention.
As I understand it, if you've flashed back to the original Iconnect image, you'll need to go through the procedure to flash to Meteohub again (holding the reset button in while powering up) with a freshly downloaded meteohub image. Once that is done, your freshly created Meteohub USB system (as well as the previously cloned USB stick) should work.
Ethernet cables do go bad, so the easiest thing to do once you've done all of the above is to get a new cable and plug it directly into your Iconnect and your router. Make sure that your router is in the correct subnet and that your router is configured to hand out the IP of 192.168.1.77. You should be able to inspect your routers log table and see the .77 connection if all is well.
Re: Sennsors error
did you try the IP the unit blinks to you after boot?
Amortalis
Re: Sennsors error
Post by Amortalis »
LMAO
Why no one tells me that I HAVE to use the router to connect to Meteohub?
I tried to connect directly!
Anyway I managed to start it again and I'm updating. If I have problems again with the ramdisk I will drop you a line.
Update finished, everything looks good.
Thanks m8s for your support.
Boris, my Paypal account is restricted since 1st of January, how can I get a license?
All the best and have a nice week-end
P.S. Meteoware Live is still empty
P.P.S. System log
2012-02-11T10:48:00.819054+01:00 localhost rsyslogd: WARNING: rsyslogd is running in compatibility mode. Automatically generated config directives may interfer with your rsyslog.conf settings. We suggest upgrading your config and adding -c3 as the first rsyslogd option.
2012-02-11T10:48:00.819081+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
2012-02-11T10:48:00.819096+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
2012-02-11T10:48:00.819113+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad imuxsock
cat: /data/weather/20*/raw: No such file or directory
expr: division by zero
2012-02-11T11:01:33.284127+01:00 localhost rsyslogd: WARNING: rsyslogd is running in compatibility mode. Automatically generated config directives may interfer with your rsyslog.conf settings. We suggest upgrading your config and adding -c3 as the first rsyslogd option.
2012-02-11T11:01:33.284154+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
2012-02-11T11:01:33.284169+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
2012-02-11T11:01:33.284185+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad imuxsock
2012-02-11T11:06:24.261379+01:00 localhost rsyslogd: WARNING: rsyslogd is running in compatibility mode. Automatically generated config directives may interfer with your rsyslog.conf settings. We suggest upgrading your config and adding -c3 as the first rsyslogd option.
2012-02-11T11:06:24.261406+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
2012-02-11T11:06:24.261421+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
2012-02-11T11:06:24.261438+01:00 localhost rsyslogd: Warning: backward compatibility layer added to follow
Re: Sennsors error
Ignore the syslog messages, they do no harm.
You can even use PayPal without an account. I guess that should work.
