Page 11 of 89
Posted: Wed Dec 04, 2019 2:01 am
by Taylor
Hi, I have found several typos in solaralmanac.php
line 122:
echo "<div class='uvtoday4-5'>",$weather["solarymax"] . "</value>";}
should be:
echo "<div class='uvtoday4-5'>",$weather["solarydmax"] . "</value>";}
line 173 and 174:
else if ($weather["solarydmax"]>=300) {
echo "<div class='uvtoday4-5'>",$weather["solarYmax"] . "</value>";}
should be:
else if ($weather["solarymax"]>=300) {
It caused issue that year max solar radiation value was shown in yesterday max solar radiation field, but only for values between 300 and 500 W/m2
Posted: Wed Dec 04, 2019 8:26 am
by weatherist34
Taylor wrote: Wed Dec 04, 2019 2:01 am
line 122:
should be:
line 173 and 174:
should be:
many thanks just updated file ..
- taylor.png (46.78 KiB) Viewed 6945 times
Posted: Wed Dec 04, 2019 10:35 am
by ToTo
In the screenshot I marked areas that are not currently translated into the selected language. Maybe this texts variable can be added to the language file?
Furthermore I would like to see the amount of rain in the glass not displayed in blue(for falling water) when there is no rain on the day?
Posted: Wed Dec 04, 2019 11:01 am
by weatherist34
New for version 1.07A
alternative slimmed console/tablet display as a permanent alternative display to the actual vp2 console or alike .
I used two old
https://apple-history.com/ipad_mini iPad mini circa 2011 I picked up really cheap if you look for the older obsolete models
https://www.ebay.com/itm/Apple-iPad-min ... SwBrRd3j7f
these are pretty much obsolete in terms of upgradeable software but all you need is the wireless access and the browser.
inside the zip there is a folder called console inside there is a file called consoledavis.php it has simple setup screen to set your metric/languages and the path to the MBrealtimeupload.txt just as you would in main template. This alternative view is very very small on resources as it as no charts , no forecast, no api etc it just displays realtime data with a few history data values.
I have setup both one on my computer desk shelf and one on our balcony , whilst I have never had a problem with the actual VP2 console I kind of like its solidness but its never viewed it just acts a provider to the NANOSD upload .
So find a cheap tablet be it a cheap obsolete iPad mini or cheap Android based tablet (check the android tablet works in landscape mode my sister in law has one that doesn't ! )
it supports the standard template languages and metrics you set them individually so you can mix and match . it has no menu system so the settings are fixed. it is not a replacement for template and it will not support anything other than realtime data from your NANOSD .
so some poorly taken photos one iPad mini mounted on window and a iPad mini on diy stand
of course some screenshots
app coming in 2020
Posted: Wed Dec 04, 2019 11:06 am
by weatherist34
ToTo wrote: Wed Dec 04, 2019 10:35 am
if you want translations done please provide correct words to use I don't speak or understand anything but English or Turkish and I certainly don't trust google translator to use, Im very sorry not doing anymore design elements with rain its just a quick reference an alternative for those not using a sensor for UV index or Solar . Brian
Posted: Wed Dec 04, 2019 11:18 am
by ToTo
I have translated it all the texts in German languages file. But the marked texts are not translatable with the current language files.
greetings
Torsten
Posted: Wed Dec 04, 2019 11:22 am
by weatherist34
ToTo wrote: Wed Dec 04, 2019 11:18 am
greetings
Torsten
send the file or is it the same one you sent last week or so ?. ill try and do it but it needs crosschecking to work in all languages not a 5 minute job todo takes a lot of time and likelihood other languages don't have the translations. I reiterate I dislike working with languages when it comes to design often it can break everything in terms of appearance can look fine in one language then awful in another.
Posted: Wed Dec 04, 2019 11:40 am
by ToTo
Yes is same file from last week. I think the marked words has no language placeholder in the php code.
Posted: Wed Dec 04, 2019 11:44 am
by ToTo
weatherist34 wrote: Wed Dec 04, 2019 11:01 am
Very nice idea, i will test it on my new iPad Pro
Posted: Wed Dec 04, 2019 11:47 am
by weatherist34
ToTo wrote: Wed Dec 04, 2019 11:40 am
ok I will take a look tomorrow and see if I can use them..many thanks
Posted: Wed Dec 04, 2019 1:39 pm
by weatherist34
ToTo wrote: Wed Dec 04, 2019 11:44 am
it is fine on iPad Pro I have one its my main tool when I'm traveling to and throw just bought a keyboard and bluetooth mouse for it last week in the Black Friday sales no longer do I need a MacBook but don't think my wife would be to keen on sticking an iPad Pro as a permanent display just for weather...
Posted: Thu Dec 05, 2019 4:14 am
by prestwickwx
weatherist34 wrote: Wed Dec 04, 2019 1:39 pm
I have a few old tablets around and I will give this a try. Looks like a nice clean way to display "quick glance" info. Look forward to the MAC app.
Posted: Thu Dec 05, 2019 10:24 am
by weatherist34
hello chuck
the web version try it out for now , in mid to late January if you want to try out the APPS ill send a link along via email. there almost identical in appearance but as a few optional buttons to use . My nephew is loaning me a Android Tablet so I have a better chance of getting it right .
@Toto Torsten I added a few changes this morning to the alternative layout version i.e last rainfall, corrected wind direction in languages but I couldn't see the reference in the language file for the Lo Hi Max Min etc I found the moon phases but looks like they break up the alignment as I guessed but give me some time I will sort it out sooner or later..
the live demo of the alternative layout is viewable here
http://singaporeweather.info/console/consoledavis.php
I always rely on Lars site in Singapore because he is in a location where I don't always see some variables often the opposite of my seasonal data .
Posted: Thu Dec 05, 2019 3:25 pm
by prestwickwx
weatherist34 wrote: Thu Dec 05, 2019 10:24 am
hello chuck
Looks great! One thing I noticed is the <meta name="mobile-web-app-capable" content="yes"> does not seem to be working, for me. I save the page to home screen via Safari, but it will not go full screen. I think I read somewhere about later versions IOS ignoring this in favor of a manifest reference. I will check into it further.
Thanks for the minimalist alternative.
Posted: Thu Dec 05, 2019 5:44 pm
by weatherist34
good day chuck
web app version just use the add to home screen , the IOS app version itself just runs in full screen I hope to have it ready sometime in January , I finished the Android version this afternoon almost just got to adjust the colors for some reason the Android produces a tinted dark blue background .
screenshot of using your url on iPad to add to home screen then it opens up with browser bar
- chuck.jpg (99.61 KiB) Viewed 6821 times
