fotogw
- Senior Boarder
Small bug in Meteobridge Aurora
I just noticed a small error in the 'Feels like' module. The graph does not show negative values. The however are shown in the pop out graph. something to put on the list;-)
hello ..
fixed many thanks will add to next update but not sure when that will be ? could possibly just send boris the one file to fix it ? . brian
screenshot of fix
screenshot of fix
yes, please send me updated file.
will do .. brian
sent .. file goes into the weather34charts folder 1 file fix ..
todayrealfeelmodulechart3.php
Update was just installed in the cloud. I hope everything works fine.
lorenz1982
- Expert Boarder
Hello! I have these error messages and weather34 is offline. How can it be solved?
- IMG_0459.jpeg (94.47 KiB) Viewed 1452 times
- IMG_0460.jpeg (131.72 KiB) Viewed 1452 times
- IMG_0461.jpeg (8.84 KiB) Viewed 1452 times
Hilorenz1982 wrote: Tue Jan 06, 2026 2:26 pm Hello! I have these error messages and weather34 is offline. How can it be solved?
1. check if host has updated PHP ? use phpini if available
2.check file/folder permissions commonly after upgrade folder/files get there permissions changed.
3.try entering the url in the browser the same as the one you setup in the meteobridge API url .see what response you get
brian..
lorenz1982
- Expert Boarder
It's Aurora in the cloud.weatherist34 wrote: Tue Jan 06, 2026 5:47 pmHilorenz1982 wrote: Tue Jan 06, 2026 2:26 pm Hello! I have these error messages and weather34 is offline. How can it be solved?
brian..
Actually, it works now without doing anything. It wasn't just my problem; this one also didn't work https://weeropdeveluwe.nl when mine didn't.
- FedeMasso
- Fresh Boarder
Hello, good morning.
I have a question; my website is this: https://climachivilcoy.com.ar
I currently have this version of Aurora (I've attached an image)
How do I update to the latest version ???
Do I have to download the version from Meteobridge...? (image attached)
And another question: I see there are two files, which one do I need to install?
- Aurora Master File
- Aurora Simple Update File
Thank you, I look forward to your reply, regards
- descarga.jpg (35.18 KiB) Viewed 1324 times
- version.jpg (27.79 KiB) Viewed 1324 times
Meteorology enthusiast, from the city of Chivilcoy, Buenos Aires Province...
LIVE DATA FROM MY EMA:
https://www.facebook.com/climachivilcoy
https://twitter.com/ClimaChivilcoy
Why does my cloud keep getting changed to this format: https://content.meteobridge.com/dashboa ... /index.php
I set it to look like this one: https://www.morewoodweather.ca/Aurora/index.php
But every so often it changes back. That is an awful visual look.
I changed it back anyway.davidmc36 wrote: Mon Feb 23, 2026 1:37 pm Why does my cloud keep getting changed to this format: https://content.meteobridge.com/dashboa ... /index.php
Seriously! This is ridiculous!!!!!! It keeps changing to layout 9 and messing up all the blocks I have. What kind of re-boot or some such stupidity is goin on????????????????????????????????????????
Hello sorry about your issue(s) but I can't help you with cloud versions at all , I simply have no access to diagnose , resolve etc simply its up in the cloud providing to multiple users .One change or hiccup would affect all users . I hope Boris switches to the newer streamlined version has the older version with 9 or 10 layouts in the cloud is way to much to maintain it needs an overhaul to be more compatible and streamlined for cloud based providing . which layout is your preferred ill try and replicate it locally and see If I see anything causing the switching but I can't modify anything in the cloud..have a good daydavidmc36 wrote: Sun Mar 15, 2026 1:41 pm Seriously! This is ridiculous!!!!!! It keeps changing to layout 9 and messing up all the blocks I have. What kind of re-boot or some such stupidity is goin on????????????????????????????????????????![]()
I use layout 1, same as my sever version: https://www.morewoodweather.ca/Aurora/index.php
When it changes, it goes to 9 and the bottom blocks change. And I lose the webcam. It's like every week or two it resets to a default.
Hello
obviously its remote reset or update ?? it simply defaults back to the default settings of installation .. layout 9 is the default . as before can't help much as its cloud based.. sorry its an issue for Boris to resolve perhaps a stored localized internal firmware 'console-settings.php' should be used so any changes in the cloud doesn't affect the configuration for the layouts ..just an idea ..Brian
