- jmontamat
A suggestion, to clarify the dashboard layouts click there a popup with them.
- Sin título.png (150.28 KiB) Viewed 8890 times
perhaps tomorrow Josep ..
- prestwickwx
Happy 2022.
I noticed my chart csv files were missing January 1 data. So I have added the missing data, but I can't remember if there is any special encoding for the updated file?
Best wishes,
Happy 2022.
Best wishes,
good evening chuck happy new year to you and family ..
it happens to me probably twice a year , i cant nail it ,it could be me my isp down,icdsoft down,overnight electric occasionally goes down district wide overnight so could be at the specific time that runs i.e 2am . normally i pick it up when i awake and simply run the service through the browser or you can simply trigger it through meteobridge itself by hitting test next to the service. if you miss it the following day and apply the data manually (edited csv) just make sure you position the cursor on the first empty line below last set of data .
brian.
brian.
- prestwickwx
I think it was probably me. I was late uploading the new rollover files. No problem, I corrected the January and 2022 files, so back to normal.
Thanks for the info.
Cheers!
Cheers!
The humidity data chart for 2021 is only shown from July?
Example from Singapor Weather:
(My station still has an older template version)
TOTO as per post way back in July 2021 below hence begins in July that's when the feature was added to charts..ToTo wrote: Mon Jan 03, 2022 6:55 pm The humidity data chart for 2021 is only shown from July?
Post by weatherist34 » Fri Jul 09, 2021 11:13 am
Josep todays update adds the month, year humidity charts to extra info for Humidity see screenshot.*note need to allow a couple of days to collect data in the CSV file after applying the update file as there are two new strings in the end of day file.
Download Update 9th July 2021
* (11:00) Adds month/year humidity charts to extra info screen
* (11:00) Humidity month/year charts allow 2 days for csv data
* (10:03) Adds temperature/dewpoint color values to extra info
* Update contains all updates since March 1st
Thanks for the Explanationweatherist34 wrote: Mon Jan 03, 2022 7:22 pm
- jmontamat
Thanks Brian for accepting the idea, it looks great like this
May I bring up another older thread on the Davis AQI chart data source meteobridgeapi[184]? You wanted to implement the solution once to the new year, is it too late for that now? My question was viewtopic.php?p=39222#p39222weatherist34 wrote: Sat Apr 10, 2021 11:18 am
idea ?
later in the the year i could just add the davis aq max,lo from previous day to the end of day and remove the 24h then it aligns with other chart data outputs for a 2am run.
as for the exclamation mark cool idea but the charts expect a value not a symbol , end of the day it is best to resolve or tackle the source of problem not disguise it .so best leave it as it is charts can be messy to update and requires a lot of testing over a few days..
good evening torsten , i need to go back digest that post unfortunately im still recovering from an illness,so complicated things may take a while for me to get my head around it.. that said anything charts is never straight forward
..brian
Hi, Apologies if this is in the wrong place. I've installed the latest download of Weather34 Aurora MkII on to a Raspberry Pi 4 running new Rasperian OS (Bullseye) installation acting as a server using Apache2 and PHP7.4. I tried PHP8.0 which just showed the index.php code in Safari V14.12 and PHP8.1.1 which just showed an empty screen. Using PHP7.4 I set up my Davis/Nano SD as described on the Weather34 website using the Raspberry Pi's localhost address (192.168.1.16) in place of a URL to access the Weather34 webpage. I can get most of the data tiles to work but tile 6 should display wind gusts, see console-setup.php, but instead shows AQI data. What's more the AQI data is not being updated. I can access my Lüfdaten data manually in Safari using the new sensor.community address in stationcron.php and adding my Lüftdaten ID. If I paste the returned data string into luftdaten.txt the data is displayed in tile 6 but is not updated with new data. Any suggestions would be gratefully received as to both why later versions of PHP do not appear to work on the Pi 4 and the tile 6 mystery. Many thanks in advance, Richard
- Screenshot 2022-01-04 at 16.25.40.png (106.71 KiB) Viewed 8746 times
- Screenshot 2022-01-04 at 16.26.01.jpg (122.1 KiB) Viewed 8746 times
- Screenshot 2022-01-04 at 16.23.33.jpg (168.72 KiB) Viewed 8746 times
- Screenshot 2022-01-04 at 16.25.07.png (67.13 KiB) Viewed 8746 times
- Screenshot 2022-01-04 at 16.24.28.png (112.12 KiB) Viewed 8746 times
good evening, i cant be of much help i dont own a rasperry and i dont have any experience with them , in fact i wouldnt know what one looks like .. i run 2 versions of 8.1.1 one native with apache install on a converted old mac mini server and one via xampp on a mac M1 with Monterey OS and a public hosted version of 8.0.2 via icdsoft . so it’s definitely fully compatible with 8 to 8.1.1.
your other issues all i can say or think is verify folder permissions , verify file permissions , misconfigured htaccess , disabled php modules ..its pretty hard to diagnose anything without some form of access but has above ive zero experience of anything rasperry and ive no idea what bullseye is apart from i play a lot of darts.
sorry its not what you want to hear but no point in me trying to help or making any assumptions. im not ignoring your call for help but im not the guy perhaps others may have some experience or perhaps more research on the web for install issues of php on rasperry..brian..
lorenz1982
- Expert Boarder
Hello Brian.
I still have the problem with the link to the 2021 UV and Solar Radiation chart. On the chart page man can see all of them.
How can I solve it, do you have any idea?
Thank you.
Thank you.
- D2665F70-4B89-485C-AE54-702D73275A0B.jpeg (193.12 KiB) Viewed 8724 times
- D8FC1A40-E77B-4C23-A50A-162099312C72.jpeg (155.05 KiB) Viewed 8724 times
- 7EF45F3F-6EDF-4885-BCF6-4BA36713DB67.jpeg (347.26 KiB) Viewed 8724 times
Good morning Lorenzo
your 2021.csv has some really bad data I guess you edited this file at some stage see below..
check for yourself http://meteoborgo.altervista.org/Weathe ... s/2021.csv
if I use your 2021.csv in the demo it's exactly the same result as you see and if I revert to demo data or use a sample from another user site I get a proper rendered chart for solar/uv for 2021 .below shows data like this till 29th March,this is causing the poor rendering of data in the charts .goint through the csv for 2021 there are many edited errors ! . if it was a template error the problem would be same for everyone using latest updates..
1 Jan,0.7,-2.2,,,0.5,,,,,,0.0,,,,
2 Jan,1.4,0.6,,,9.8,,,,,,0.0,,,,
3 Jan,4.9,1.1,,,45.6,,,,,,0.0,,,,
4 Jan,1.8,-0.9,,,1.6,,,,,,0.0,,,,
5 Jan,1.9,-1.3,,,1.3,,,,,,0.0,,,,
6 Jan,2.7,0.5,,,3.1,,,,,,0.0,,,,
7 Jan,3.3,-4.1,,,1.1,,,,,,0.0,,,,
8 Jan,0.7,-7.2,,,0.5,,,,,,0.0,,,,
9 Jan,-1.9,-8.4,,,0.0,,,,,,0.0,,,,
10 Jan,-0.3,-7.7,,,0.0,,,,,,0.0,,,,
11 Jan,-1.3,-10.8,,,0.0,,,,,,0.0,,,,
I hope that helps..Brian
