Page 16 of 89
Posted: Tue Dec 31, 2019 8:39 pm
by xxvincixx
weatherist34 wrote: Tue Dec 31, 2019 8:29 pm
xxvincixx wrote: Tue Dec 31, 2019 7:53 pm
hello Brian, I just installed version 2.0, everything went well except for the problem that I report in the photo ... what should I do to fix it ??
Good evening
I would probably guess its lat/lon related ? timezone related generally what causes that module to go blank when either a typo or a hidden space is inserted or incorrect typed timezone structure . if you get stuck pm url with password to setup which you can change at any time .
if possible pm before end of tomorrow of on our travels again..
oooh god, I had reversed Europe / Rome with Rome / Europe
all solved, thanks and happy new year
Posted: Wed Jan 01, 2020 10:40 pm
by Lespius
Hello Brian, and All
Hope you had a great evening yesterday.
Thank you for the correction.
But now I have a question about updates... I need someone's help.
New updated files are available almost everyday when you do a modification after, a request from users and everyone seems to be able to upload them. I don't know how to.
I have followed the explanation on the MB-SMART site, ie open the settings and click on "UPDATE or RUN A BACKUP". The updater opens but no new MB-SMART-UPDATE-XXXXX.zip is available. So how to proceed ?????
Then I tried to download the version 2.0, because I am running the 1.07A. I did it successfully, but lost my data (the *.csv files). I was able to retrieve them, but in fact I am not sure to run the version 1.07A, because it my menu on the left, it still shows *DOWNLOAD MB-SMART VER 1.07A". For info I also lost part of my settings, not all.
Well, as you understand, I am missing the point somewhere...
Thank you !!
Alain
Posted: Wed Jan 01, 2020 11:27 pm
by weatherist34
Hi as of January 1st smart updates are available to be used with
version 2.0 onwards this was planned for some months to release updates via that method after January 1st.
install version 2.0 and thereafter you can use the simple updater if and when they are available .the current version 2.0 download as all the updates pre installed as of January 1st !
in the future simply download the update zip i.e 31FEB2020.zip and place it in the main folder where the template is installed on your server. the updater will find it and it will appear in the dropdown just select and click update.
don't use the updater for version 1.07A or earlier because the updater will only have a small amount of files with fixes for version 2.0 only.
This was was used for a short period in 1.07a to test and iron out any issues prior to January 1st 2020.
as it January 1st 2020 now or later the 2019 chart data is not used unless you modify the charts for your own personal use or preference to display last year or year before etc depending on many years you have been using I have it back to 2017 and sometime this year I will try and introduce charts to support previous years on a separate page like the alternative version charts but thats something for the future.
settings1.php is the file you need to keep a copy on your PC for keeping settings and using if you don't want to go through the setup procedure .just simply keep a copy on your desktop and upload it when you have done new install . No changes were made to the main settings1.php or setup screen.
Only the alternative layout had a minor change to setup screen based on 12/24 clock .
Im really sorry but as of tomorrow(Jan 2nd) morning Im not available for some weeks so I can't be of much assistance to help you or try and explain in easier terms.Ive done my best to prepare everything for January 1st 2020 and addressed the minor metric/non metric setting issues today but Im out of time for a while and
could be longer I have had an offer of a 2 year deal to work on a project thankfully not weather related still digesting it and whether I want to make that commitment on a monday-friday basis kind of got used to my own time and doing things without obstacles of commitments to work schedules .
Sorry your confused or missing something but time is not on my side for now. Perhaps others can help there are quite a few knowledgeable experienced users around that have been a constant help for a few years now.
still confused ? probably even more so now
weather stuff is never straight forward in fact Im beginning to loathe it , it is a tedious task maintaining a template with all the complexity of non metric versus metric versus languages doesn't matter how hard I try always something pops it head up and think to myself how did that occur ,how did I mess that up because its generally me that screws up
can only say always allow a bit of time to learn and become accustom too to something new unfortunately Im not the best educator I just tend to do it rather than explain it . Brian...
Posted: Thu Jan 02, 2020 1:28 pm
by ToTo
I have a error on Raintotal Alamanach?
We haven't had rain in 2020, but in December 2019.
Posted: Thu Jan 02, 2020 2:11 pm
by weatherist34
checking across some sites but most have had some rainfall last 24 hours only two I could find that had not had any rain was showing no anomaly so I don't know the answer and my home PC is shutdown so I can't look at any files remotely .
I checked these two
http://www.bobhewitt.co.uk/MBSMART/
http://singaporeweather.info
Posted: Thu Jan 02, 2020 2:36 pm
by Taylor
I have the same problem. See
http://novosady.eu/PWS/
Posted: Thu Jan 02, 2020 3:22 pm
by weatherist34
as above I've no idea but I suspect something amiss in the API output or how meteobridge interprets old data
bob's api output
02/01/2020 13:14:16 9.5 92.0 8.3 0.9 0.9 244.0 0.0 0.0 1019.5 225.0 1 m/s C hPa mm 1.2 1020.4 0.0 0.0 0.0 18.9 54.0 9.5 8.9 9.5 20200102130436 5.8 20200102000046 0.9 20200102130704 4.9 20200102122046 1026.9 20200102000006 1019.4 20200102131206 4.2 13290 4.5 CARAMBOLA2 -- 0.0 0.0 46.0 226.0 0.0 8.4 20200102113250 0.9 20200101054229 5.5 20200101234646 8.4 20200102113250 0.9 20200101054229 0.7 98.0 20200102000046 92.0 20200102130838 8.4 20200102113250 5.5 20200102000046 9.4 93.0 8.3 18.9 54 1.1 0.9 -- -- -- -- -- -- 155.0 89410 5.8 20200101234646 1.3 20200101054229 9.5 20200102130436 1.3 20200101054229 9.5 20200102130436 1.3 20200101054229 0.0 20200101000017 4.9 20200102122046 4.9 20200102122046 0.0 0.0 20200101000041 0.0 20200101000041 155.0 20200102122018 63.0 20200101103141 155.0 20200102122018 155.0 20200102122018 20200102121754 0.5 20200101101445 0.7 20200102121754 0.7 20200102121754 0.9 20200101054229 1 9.3 -- 37.1 20190725135554 -4.1 20190131070628 25.1 20190725183632 -10.5 20181101215107 13.9 20181221133359 1031.3 20200101001207 1026.8 20200101235906 1031.3 20200101001207 1019.4 20200102131206 1031.3 20200101001207 1019.4 20200102131206 1043.9 20190102094513 970.4 20191213014213 1137.6 7.0 2 43.8 07:57 11:52 23:49 0.1 99.0 20200101061647 92.0 20200102130838 99.0 20200101061647 92.0 20200102130838 99.0 20200101061647 95.0 20200101000017 0.0 0.0 46.0 590.2 -- 9.5 1019.5 0.3 0.9 55.2 8.3 0.0 92.0 5.6 0.1 20181019122801 20181019122801 20181019153437 20180131230000 20200101000041 175.0 9.5 20200102130436 1.3 20200101054229 _Increasing clouds and warmer. Precipitation possible within 12 to 24 hours. Windy.
see your api output you can see the string
[rain0total-max@M1] in your output.I have absolutely no way of determing how that happens or have any control over it has that is a generated string from the meteobridge itself.
http://novosady.eu/PWS/mbridge/MBrealtimeupload.txt
Taylors output
02/01/2020 14:16:02 6.2 49.0 -3.7 0.4 0.0 260.0 0.0 0.0 1032.2 260.0 0 m/s C hPa mm 0.4 1032.7 0.0 0.0 0.0 25.2 33.0 6.2 6.9 7.3 20200102121459 -3.1 20200102014123 2.2 20200102080605 3.6 20200102083623 1035.4 20200102002012 1032.1 20200102141007 4.2 2681 1.3 VOCORE2 -- 0.5 0.0 76.0 260.0 0.0 -0.8 20200101130047 -18.5 20200102062129 -0.8 20200101130047 -0.8 20200101130047 -18.5 20200102062129 1.2 88.0 20200102014627 19.0 20200102062129 -1.4 20200102135203 -18.5 20200102062129 6.3 50.0 -3.4 25.3 33 0.6 0.7 -- -- -- -- -- -- 371.0 1265726 2.6 20200101130047 -2.3 20200101235934 7.3 20200102121459 -3.1 20200102014123 7.3 20200102121459 -3.1 20200102014123 7.6 20200101004724 7.6 20200101004724 7.6 20200101004724 0.0 0.0 20200101000011 0.0 20200101000011 371.0 20200102114630 313.0 20200101130815 371.0 20200102114630 371.0 20200102114630 20200102114635 1.0 20200101112837 1.2 20200102114635 1.2 20200102114635 -4.5 20200101235750 1 6.3 -- 33.3 20190701141506 -6.9 20191230011615 21.7 20190626150238 -18.5 20200102062129 13.4 20191220102405 1036.7 20200101115705 1033.9 20200101040607 1036.7 20200101115705 1032.1 20200102141007 1036.7 20200101115705 1032.1 20200102141007 1041.9 20191229093505 988.6 20191213131305 340.4 1.9 2 43.8 08:16 11:43 23:40 0.8 88.0 20200101173850 19.0 20200102062129 88.0 20200101173850 19.0 20200102062129 88.0 20200101173850 77.0 20200101105857 0.0 0.0
[rain0total-max@M1] 340.4 -- 6.3 1032.2 0.5 0.6 79.8 -3.8 0.0 48.4 1.0 1.0 20190623004827 20190623000037 20190623004807 20190623000051 20200101000011 316.0 7.3 20200102121459 -6.4 20200101064731 _Increasing clouds and warmer. Precipitation possible within 24 to 48 hours.
classic change of year teething issue that doesnt arise all year round so chances of resolving prior is almost zero . as above Ive no remote access to any files on my home PC as I shut it down so it will be like that for a number of weeks Im afraid unless anyone has a solution or fallback to use.
Posted: Thu Jan 02, 2020 5:35 pm
by ToTo
The morning dew (0.2mm) has solved my problem.
Posted: Thu Jan 02, 2020 5:55 pm
by prestwickwx
weatherist34 wrote: Thu Jan 02, 2020 3:22 pm
bob's api output
Taylors output
It also looks like we are dealing with two different versions of the Template. The Rain Almanac Module on my template (latest version), Ron's and Toto's is showing Rain - # of days ago. The other's are showing December rain. Also, in my case the rainalmanac.php is showing rain in December as 0.00.
- Capture.PNG (49.79 KiB) Viewed 5626 times
Toto's
- Capture1.PNG (61.59 KiB) Viewed 5626 times
Posted: Thu Jan 02, 2020 7:03 pm
by weatherist34
hi chuck
there has been no change to either almanac rain or main month year rain modules scripts the template will only display what is generated from meteobridge in the api. the template does not control what is sent to it .so i am at a loss of what can be done from template side apart from removing the feature. basically the december value of 0.0 is what is in the api data so upto January 1st this was not visible so im leaning towards an anomaly related to change of year and how last months december 2019 data is interpreted in the api. if anyone has any ideas im all ears . so possible thought is does the string [rain0total-max@M1] only work in current year ?
Posted: Thu Jan 02, 2020 7:15 pm
by weatherist34
to add to the confusion here is Singapore weather showing last months rainfall total ..orange dot area ..
the string used is [rain0total-max@M1] based on the template variables listed in the wiki
@Mn addresses monthly data n months in the past.
Example: "[wind0wind-max@M0] will return max wind speed of current month, while "[wind0wind-max@M1]" will return max wind speed of previous month.
- Singapore Home Weather Station.png (218.79 KiB) Viewed 5611 times
77.4 in bold red below
03/01/2020 01:18:51 26.8 88.0 24.6 2.2 3.1 207.0 0.0 0.0 1015.8 184.0 2 m/s C hPa mm 2.0 1016.4 0.0 0.0 0.0 29.6 48.0 26.8 26.9 27.0 20200103000028 26.7 20200103011413 2.7 20200103002837 5.8 20200103001120 1016.6 20200103000104 1015.8 20200103010839 4.2 2681 4.9 VOCORE2 -- 0.0 0.0 0.0 188.0 0.0 25.8 20200102102310 23.1 20200101144007 25.8 20200102102310 25.8 20200102102310 23.1 20200101144007 0.0 88.0 20200103000028 87.0 20200103000328 24.8 20200103000028 24.5 20200103000348 26.8 88.0 24.6 29.6 48 2.1 1.9 -- -- -- -- -- -- 0.0 131801 31.3 20200102114450 25.7 20200102062339 32.6 20200101132712 25.7 20200102062339 32.6 20200101132712 25.7 20200102062339 9.8 20200102132712 11.6 20200101122738 11.6 20200101122738 0.0 0.0 20200101000045 0.0 20200101000045 0.0 20200103000104 868.0 20200102104918 1136.0 20200101132344 1136.0 20200101132344 20200103000104 6.6 20200102113116 10.4 20200101132352 10.4 20200101132352 23.8 20200102142816 0 26.8 -- 35.7 20190419134207 22.1 20190311162152 28.2 20190610150525 16.9 20190318192827 14.3 20190508101248 1017.4 20200102100240 1012.8 20200102155047 1017.4 20200102100240 1012.7 20200101162453 1017.4 20200102100240 1012.7 20200101162453 1017.7 20190220104455 1005.7 20190421165849 1730.6 26.8 2 45.4 12:03 13:09 00:48 1.9 93.0 20200102063055 61.0 20200101122750 93.0 20200102063055 61.0 20200101122750 93.0 20200102063055 69.0 20200102151252 0.0 0.0
77.4 1653.2 -- 26.8 1015.8 0.0 2.2 0.0 24.6 0.0 88.0 27.7 2.2 20181208163429 20181208163117 20181208171507 20181208162754 20200101000045 180.0 39.9 20200101132712 25.7 20200102062339 _Increasing clouds with little temperature change. Precipitation possible within 24 to 48 hours.
yours at the moment chuck
02/01/2020 12:22:49 13.3 52.0 3.6 0.4 0.4 185.0 0.0 0.0 1017.6 184.0 1 m/s C hPa mm 0.5 1018.4 0.0 0.0 0.0 20.7 45.0 13.3 13.8 13.9 20200102111755 5.9 20200102011212 0.6 20200102101535 3.3 20200102120943 1019.0 20200102102939 1015.1 20200102001942 4.2 2629 2.0 VOCORE2 -- 1.2 0.0 195.0 178.0 0.0 5.5 20200102100439 -0.1 20200101130819 2.9 20200101233108 5.5 20200102100439 -0.1 20200101130819 1.7 81.0 20200102012036 41.0 20200102112339 5.5 20200102100439 0.6 20200102112339 13.7 50.0 3.5 20.7 45 0.7 0.4 -- -- -- -- -- -- 315.0 5626287 15.4 20200101141801 5.4 20200101072955 15.4 20200101141801 5.4 20200101072955 15.4 20200101141801 5.4 20200101072955 8.7 20200101132657 8.7 20200101132657 8.7 20200101132657 0.0 0.0 20200101000036 0.0 20200101000036 315.0 20200102111429 670.0 20200101120209 670.0 20200101120209 670.0 20200101120209 20200102111349 2.3 20200101115023 2.3 20200101115023 2.3 20200101115023 -0.1 20200101130819 0 13.5 -- 38.5 20190528150000 -8.3 20180107060000 28.2 20190810135117 -20.5 20190121110000 28.2 20190905182901 1016.8 20200101211537 1011.1 20200101012338 1019.0 20200102102939 1011.1 20200101012338 1019.0 20200102102939 1011.1 20200101012338 1049.1 20141015190000 976.6 20161008130000 1103.3 8.5 2 45.4 09:59 12:07 -- 0.1 81.0 20200102012036 36.0 20200101141049 81.0 20200102012036 36.0 20200101141049 79.0 20200101233108 36.0 20200101141049 0.0 0.0
[rain0total-max@M1] 1103.3 -- 13.4 1017.6 1.1 0.6 170.0 3.4 0.0 50.9 8.9 0.2 20180107060000 20180914080000 20141015190000 20190101090000 20200101000036 292.0 15.4 20200101141801 2.7 20200101081415 _Increasing clouds with little temperature change. Precipitation possible within 24 to 48 hours.
another this time uk in bold red for last month so I have no idea how to approach this apart from remove feature or take some mescaline and come back when its all over
02/01/2020 17:45:52 10.8 86.0 8.6 3.1 3.1 199.0 0.0 0.2 1014.6 194.0 2 m/s C hPa mm 3.1 1015.3 0.4 0.4 0.2 20.8 42.0 9.0 10.6 10.8 20200102174346 7.7 20200102050222 4.0 20200102124210 8.5 20200102173142 1024.9 20200102000013 1014.5 20200102173810 4.1 2582 8.0 VOCORE2 -- -- 0.2 0.0 196.0 0.0 8.6 20200102174346 4.2 20200101012921 7.7 20200101230936 8.6 20200102174346 4.2 20200101012921 -- 94.0 20200102032629 82.0 20200102124049 8.6 20200102174346 6.3 20200102051731 10.7 86.0 8.5 20.8 42 3.5 3.2 -- -- -- -- -- -- 86.0 3235240 8.6 20200101230936 5.8 20200101061157 10.8 20200102174346 5.8 20200101061157 10.8 20200102174346 5.8 20200101061157 5.4 20200101002433 8.5 20200102173142 8.5 20200102173142 0.2 0.4 20200101000011 0.4 20200101122729 86.0 20200102110350 72.0 20200101134932 86.0 20200102110350 86.0 20200102110350 -- -- -- -- -- -- -- 4.2 20200101012921 0 10.7 20200102032412 33.7 20180727160000 -6.1 20190203073130 21.6 20190629125639 -7.2 20190203073130 20.1 20190207022510 1029.6 20200101104111 1024.9 20200101235712 1029.6 20200101104111 1014.5 20200102173810 1029.6 20200101104111 1014.5 20200102173810 1045.0 20190102102013 968.9 20191221195916 1471.8 9.3 2 45.4 07:58 12:02 -- 1.9 95.0 20200101103100 82.0 20200102124049 95.0 20200101103100 82.0 20200102124049 95.0 20200101103100 85.0 20200101000955 0.0 0.0
107.3 791.8 -- 10.7 1014.5 -- 3.5 0.0 8.5 0.0 86.0 8.2 1.4 20180206040000 20180214040000 20180805020000 20180602010000 20200101000011 174.0 10.8 20200102174346 3.6 20200101041103 _Mostly cloudy and cooler. Precipitation likely. Windy with possible wind shift to the W, NW, or N.
Posted: Thu Jan 02, 2020 7:46 pm
by xxvincixx
hi brian,i've this issue...what could be caused ?? and how to solve ??? thank you
I only noticed now that other users also have the same problem ...
Posted: Thu Jan 02, 2020 7:47 pm
by prestwickwx
weatherist34 wrote: Thu Jan 02, 2020 7:15 pm
Yes, I see what you mean. Strange. My firmware is a little behind, but I don't see anything in the newer releases that would change the API. I do see that Boris has just released a new one.
Posted: Thu Jan 02, 2020 8:01 pm
by weatherist34
chuck I don't see anything in recent firmware releases related to that string in the API has been there almost a year so im really guessing its a change of year thingy but why some have it and some don't is the mystery and I really have no idea .
Posted: Thu Jan 02, 2020 8:10 pm
by prestwickwx
weatherist34 wrote: Thu Jan 02, 2020 8:01 pm
Yes, That’s what it looks like. Singapore is 13 hours ahead of me, so perhaps we will see a change later on. Maybe Boris will spot it, as well.
Take care,
