Windy.com API upload from Meteobridge
SANdood
Re: Windy.com seeking input on developing API - Let's make Meteobridge first
Post by SANdood »
Is there any chance of adding support for multiple Stations per API Key (the API apparently supports it)?
Such would be nicer than having to create separate Windy accounts for each Station.
galfert
Post by galfert »
SANdood wrote: Mon Apr 29, 2019 1:48 pm Is there any chance of adding support for multiple Stations per API Key (the API apparently supports it)?
That is exactly how Windy works. You use the same Windy account with the same API if you want create multiple Windy stations. Pretty similar to other online weather services that let you create multiple stations with one account; WU, PWSweather, WeatherCloud, Metoffice WOW, Openweathermap to name a few that let you have multiple stations with one account.
To get started go to https://stations.windy.com
Meteobridge RPI | GW1000
Yes, but Meteobridge can only feed one (and only supports one connected station). Using multiple Meteobridges would be needed.
SANdood
Post by SANdood »
Yes, I have two Meteobridges.
I'd like to have only one Windy account, with two stations. I'd configure one as `station: 0` and the other as `station: 1`.
For this to work, the Meteobridge would have to add support for specifying the station number in addition to the API key.
galfert
Post by galfert »
Ahaaaa !!! Good point!
I would suggest for now to use the HTTP method under the Services tab and be sure to include the station=1 tag.
https://stations.windy.com/pws/update/XXX-LONG-API-KEY-HERE-XXX?station=1&winddir=[wind0dir-avg2]&windspeedmph=[wind0wind-avg2=mph]&windgustmph=[wind0wind-max10=mph]&tempf=[th0temp-avg5=F]&rainin=[rain0total-sum60=in.2]&baromin=[thb0seapress-min1=inHg.2]&dewptf=[th0dew-avg1=F]&humidity=[th0hum-avg1]&uv=[uv0index-avg5]
Re: Windy.com API upload from Meteobridge
I send my meteo data with meteobridge nano. The shortest intervall is 5min, can i send shorter with http send method?
It seems for me, meteobridge sends the actually wind direction. Would not it be better, send AVG wind direction?
A Bug in Meteobridge Windy Support?
https://community.windy.com/topic/8186/ ... n-interval
galfert
Post by galfert »
ToTo wrote: Wed May 08, 2019 2:16 pm I send my meteo data with meteobridge nano. The shortest intervall is 5min, can i send shorter with http send method?
I totally agree. Wind direction should be averaged and not actual. I'm using 2 minute average with HTTP method to cut down on wind vane flutter. This is the suggestion from Windy as they stated they have adopted this from CWOP.
Yes you can send in less than 5 minute upload increments as I read a Windy employee say, but they will throw it out and only keep every 5 minutes. So there is no benefit in sending quicker than 5 minutes.
But there could be some benefit to HTTP method as you can then tweak the variables to your preference. I think Boris should publish the current Windy variables used.
Here is my HTTP method string:
https://stations.windy.com/pws/update/X ... X?winddir=[wind0dir-avg2]&windspeedmph=[wind0wind-avg2=mph]&windgustmph=[wind0wind-max10=mph]&tempf=[th0temp-avg5=F]&rainin=[rain0total-sum60=in.2]&baromin=[thb0seapress-min1=inHg.2]&dewptf=[th0dew-avg1=F]&humidity=[th0hum-avg1]&uv=[uv0index-avg5]
Wind AVG2 is fixed in Release 4.0 May 10, 2019
Wessel
Post by Wessel »
I have 7 weather stations with MB and the configuration is ok. All show that data is being sent to Windy, however just one appear as PWS, the other 6 stations appear as MADIS and if I check at stations.windy.com/stations, for the 6 stations there is no data bein sent. MB says data is being sent and Windy says it's not receiving data. API Key works just for one station or multiple?
galfert
Post by galfert »
Wessel wrote: Fri Aug 02, 2019 3:57 pm I have 7 weather stations with MB and the configuration is ok. All show that data is being sent to Windy, however just one appear as PWS, the other 6 stations appear as MADIS and if I check at stations.windy.com/stations, for the 6 stations there is no data bein sent. MB says data is being sent and Windy says it's not receiving data. API Key works just for one station or multiple?
On the Metobridge using the Weather Network tab Windy option you can only upload to the first Windy station. To upload to other stations on your Windy account you need to use the Services tab and custom configure an HTTP upload to Windy. Using the HTTP upload method you need to specify which station you are uploading to. The syntax is station=1 if you are uploading to station #2 because #1 is station=0. If you omit station=0 then it defaults to it anyway...which is what the Windy configuration does under the Weather Network tab.
More details on HTTP upload method:
https://www.wxforum.net/index.php?topic ... #msg376837
It might be a good recommendation as a firmware upgrade if Metobridge were to allow you to specify station number under the Weather Network tab settings. To remove confusion I would have a check box that is on by default and is called default station. Then when you uncheck the box a fill in field shows up or becomes available to allow you to enter a station #.
Wessel
Post by Wessel »
Thanks gus, it worked! Yes, the only one station that Windy was receiving data was ID 0.
Yes, it would be great if we could set station ID under the Weather Network tab settings.
Do I get it right that it only needs to add "&station=X" to the URL to tell Windy what station the data is good for? This should be easy to add.
Will IDs 0 to 9 be sufficient?
Wessel
Post by Wessel »
admin wrote: Mon Aug 05, 2019 9:23 pm Do I get it right that it only needs to add "&station=X" to the URL to tell Windy what station the data is good for? This should be easy to add.
Yes, I added "&station=X" and at the same time start sending data correctly. Now I have duplicated stations (PWS and Madis). Maybe 9 would be sufficiente for almost all users, but nowadays I have 7 stations...next year probably more than 9...we can have unlimited stations at windy.com.
Added to just released version.
