After update to 4.1 no FTP upload and historical data missing. **solved**
wsnoordbergum
Re: After update to 4.1 no FTP upload and historical data missing.
Post by wsnoordbergum »
Seems like the history file is corrupted so MB can't load twhe data.
Or in worst case scenario, the file is deleted from the server.
I hope the problem can be fixed.
Wsnoordbergum
heersje
Post by heersje »
It looks like Meteobridge 4.1 (Aug 31 2019, build 13123) is working now without FTP issues or historic data loss on my TL-MR3020. So what remains is manually reentering historic data
wje
Post by wje »
Are there any updates on a 4.1 fix for MR3040?? 4.0 works, 4.1 does not.
In 4.1 I am unable to "Reload template" and receive error: Error (Event #02): Download of template failed: /bin/sh: /home/openssl/wget-ssl: not found.
This error does not occur in 4.0.
In 4.1 my FTP test is failing with: Error: FTP test upload failed: sh: ncftpput: not found
It works fine in 4.0.
Also, my history is gone.
Just applied the fix to MR3040 platform. Please reboot.
ve7gel
Post by ve7gel »
heersje wrote: Tue Sep 03, 2019 8:38 am It looks like Meteobridge 4.1 (Aug 31 2019, build 13123) is working now without FTP issues or historic data loss on my TL-MR3020. So what remains is manually reentering historic data
Same situation here. FTP is now working with this build, just missing historical data.
wje
Post by wje »
I applied the Sept 5 update (Meteobridge 4.1 (Sep 4 2019, build 13124), FW 1.4 ).
Still not working.
When I press "Reload Template" I receive:
System Message
Error (Event #02): Download of template failed: /home/openssl/wget-ssl: can't load library 'libc.so'
wje
Post by wje »
I've updated to the newest release of 4.1 (September 7, 2019) and now my 3040 is stuck in a never-ending reboot cycle.
How can I recover from this? Anything above 4.0 on the 3040 is outright not working for me.
wsnoordbergum
Has anyone tried the latest version on a TP-Link TL WR703N yet?
I'm still running the 3.9 version, which is running smoothly.
I'm afraid I loose my data again when updating to 4.1
Only if 4.1 is absolutely fine and bug free, I will ty it.
wsNoordbergum
Remaining problem seems to just impact the less commonly used MR3040 only. Unfortunately, I could not reproduce the issue on my test equipment so far.
wje
Post by wje »
Does this mean the MR3040 is not supported anymore? It works fine with the 4.0 release, but nothing later.
it is supported and runs great here.
Screenshot 2019-09-11 at 16.46.13.png (108.96 KiB) Viewed 6306 times
@wje: without a direct look at your system I will not be able to troubleshoot this as it works fine on my rig.
wje
Post by wje »
@admin - I've sent you a message with my meteobridge info
Running the latest Meteobridge 4.1 (Sep 14 2019, build 13143), FW 1.4 on a 3040
When I try "Reload Template" I still receive:
I think this is why my ftp stopped working - it can't pull the template to form the file.
Other services like mySQL and PWS work fine.
My template is stored on a website which requires https. Again, it works on 4.0, but not any release since then.
with just released update issue is fixed for TL-MR3040 platform. It was a missing install statement for this particular HW platform. Sorry, that it did take so long.
galfert
Re: After update to 4.1 no FTP upload and historical data missing. **solved**
Post by galfert »
What about the other issue....missing historical data. Is there a way to get it back?
Meteobridge RPI | GW1000
