After update to 4.1 no FTP upload and historical data missing. **solved**
wsnoordbergum
Post by wsnoordbergum »
I updated tot 4.1 version, but then FTP does not work.
Also my history min/ max values are missing.
F.i. my year max temp is now yesterdays max.
I changed the value manually.
All time records also gone.
This is so s...t.
I rolled back to 4.0 FTP works again.
But my history data is messed up.
Thankfully I also use weather34 template with MySQL, so data is not completely lost.
Wsnoordbergum.
Re: After update to 4.1 no FTP upload and historical data missing.
I don't see any reason why FTP should not work. I can't remember having touched this long time. When you give me remote login, I can try to investigate. Anybody else having problems like this?
4.1 (Aug 19, 2019, build 13093) FTP appears ok.
ConligWX
Post by ConligWX »
Meteobridge 4.1 (Aug 27 2019, build 2399), FW 1.3 working too.
stephane01
Post by stephane01 »
Same problem here with last update, ftp does not work.
Fout: FTP test upload mislukt: sh: ncftpput: not found
stephane01 wrote: Wed Aug 28, 2019 6:54 pm Same problem here with last update, ftp does not work.
Which HW platform do you use?
wsnoordbergum
That's exactly the same problem.
Is your data intact?
ConligWX
Post by ConligWX »
wsnoordbergum wrote: Thu Aug 29, 2019 7:42 am That's exactly the same problem.
Perhaps you two guys could enlighten Boris as to what hardware platform Meteobridge is running on so he can diagnose the issue.
wsnoordbergum
Boris is adressing the problem through remote access....
stephane01
admin wrote: Wed Aug 28, 2019 10:55 pm
Tplink-MR3020
and also my history data are gone.
wsnoordbergum
stephane01 wrote: Thu Aug 29, 2019 11:20 am
Tplink-MR3020
I'm using a tp-link tl-wr 703n.
Maybe a tp- link related issue?
ve7gel
Post by ve7gel »
I too am experiencing the same issue since updating to 4.1. Also using a TPLink MR3020. The error received is "ncftpput: not found (no more tries):" History is also gone.
Reverting to 4.0 restores ftp service, but the history data appears to be toast.
wsnoordbergum
Looks like the problems seem to effect Dutch users?
:shock:
ve7gel
Post by ve7gel »
I'm not Dutch...Canadian. :)
wsnoordbergum
Ok, not language related then....
I hope the problem can be fixed.
Now also having problems with logging on to the MB.
I use fixed IP adress, but only after reboot MB I'm able to log on.
Cumulus is also not able to access MB through port 22222 and the IP adress.
For now I will leave everything as it is, so admin can troubleshoot the problem.
