Page 3 of 3
Re: wrong system time after reboot **solved**
Posted: Wed Jan 26, 2022 11:54 pm
by jpouyaud2
Hi lorenz1982
I confirm I've the same issue.
it's occurs sometime...
check your raw sample (for this timeline), they have been corrupted as meteobridge is not aware it's not synced yet with the right time
cheers
Posted: Wed Jan 26, 2022 11:57 pm
by lorenz1982
jpouyaud2 wrote: Wed Jan 26, 2022 11:54 pm
Hi lorenz1982
cheers
Yes the old data is overwritten.
Posted: Thu Jan 27, 2022 2:23 pm
What HW platform are you operating on?
Posted: Thu Jan 27, 2022 2:36 pm
by lorenz1982
admin wrote: Thu Jan 27, 2022 2:23 pm
I have a meteobridge installed on Raspberry Pi 3 Model B +. First I had the TP-LINK and I have recovered the settings.
Posted: Wed Feb 02, 2022 1:57 pm
by lorenz1982
Today I rebooted to install the update and the date went back to January 12, 2022.
Posted: Fri Feb 04, 2022 5:30 pm
by jpouyaud2
This is also what I've reported.
The jump in the past was related to previous reboots. (nothing more consistent).
After each jump in the past, the DB was corrupted and I've spend 1h to find and erase the wrong minute record
cheers
Posted: Fri Feb 04, 2022 5:35 pm
by jpouyaud2
This is why I've requested a feature where the Meteobridge SW start to record RAW only when an ntpq confirm the ntp client is synced to an NTP server with a "*"
after the boot, we should start with "ntpdate" then "ntpd" sync to 2 servers min
I don't know the feasibility with OpenWRT.
if it works it will be much more rock solid
Posted: Fri Feb 04, 2022 6:27 pm
just released update should have the issue fixed.
Posted: Fri Feb 04, 2022 9:40 pm
by jpouyaud2
cool !!
thank you
Posted: Fri Feb 04, 2022 9:57 pm
by jpouyaud2
ok
I've just upgraded
Reboot
and all green
first time I've a clock synchronized after the first reboot
looks promissing
Posted: Sat Feb 05, 2022 10:07 pm
by jpouyaud2
Hi
problem still present
did a reboot this evening for a maintenance
unfortunately the meteobridge reboot at the time of the last reboot (yesterday -24h) and wrote the DB in the past
after a second reboot. prb solved
please, before write the DB, check if the time is accurate
Posted: Tue Feb 08, 2022 9:29 am
Version 5.3 should have this solved. If not please send credentials for remote login again to "into(at)meteobridge.com".
Posted: Tue Feb 08, 2022 12:03 pm
by jpouyaud2
Oki,
I've activated the remote login
looks like this issue occurs when the reboot is after let's say 1 day after the previouvs reboot but It's not 100% the case..
Posted: Tue Feb 08, 2022 3:52 pm
I still think this is solved. But lets wait a few days if newest version still show issues.
